Year of Engine...
   / Year of Engine... #1
WilliamBos
Super Member
Innisfil, Ontario, Canada
MF 1635 12x12 Powershuttle
Hi All,
Is there a way, by looking at serial numbers to tell what year an engine was produced?? I am really curious to find out what year our 1523 falls under.
We bought it in March 2008, and was on the lot in December 2007.
The reason I am asking is the manual lists CC as the oil spec, and I want to know if we can safely run the new spec CJ-4 synthetic oils with out causing any harm.
UPDATE:
Just found the "Factory Recommended PDI dealer check list from Soo Tractor Sweep rake, dated 6-19-07. I assume this was the year it was built? So CJ-4 oil is what we should run??
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2012 John Deere Gator HPX 4x4 Utility Cart (A51691)
2012 John Deere...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A52748)
2024 BCL...
2007 Ford Ranger Pickup Truck (A50323)
2007 Ford Ranger...
