Yazoo S-26 High Wheel Mower awakens!
   / Yazoo S-26 High Wheel Mower awakens! #1
ultrarunner
Epic Contributor
SF Bay Area-Ca Olympia WA Salzburg Austria
Cat D3, Deere 110 TLB, Kubota BX23 and L3800 and RTV900 with restored 1948 Deere M, 1949 Farmall Cub, 1953 Ford Jubliee and 1957 Ford 740 Row Crop, Craftsman Mower, Deere 350C Dozer 50 assorted vehicles from 1905 to 2006
I was looking around my brother's new place while we were waiting for his new L3800 Kubota to arrive and found an old High Wheel Yazoo Mower under a piece of tin out behind the barn just like this.
The wheels were sunken in the dirt a few inches with vines wrapped around them.
Dragged it over the the Shop Building (Only shed with concrete floor) and started to tinker with it.
Oil was good, Deck looked good as did the belts.
Retrieved the sunken in the rim tire tube stems and added a little slime to each and filled to 35 psi.
Added a little fuel and found the rubber line leaked as fast as I put fuel in.
Replaced the line and fixed the throttle cable and added a little gas.
Pulled of the air cleaner element and gave it a shot of starting fluid and it started on the second pull.
That old Cast Iron Industrial 8hp Briggs engine sounded darn good and ran clean.
Did a few laps around the yard and cut sweet...
Not familiar with YAZOO mowers... looks like it was made to last and built like a tank!
   / Yazoo S-26 High Wheel Mower awakens! #2
Back in the day Yazoo Mowers were manufactured in Jackson, Mississippi. At the time they were the best mower you could buy.
Johnson Big Wheel Mowers was a cross-town rival built in Ridgeland, Mississippi by former Yazoo employees.
I have a Johnson Big Wheel mower 26" cut with 8 HP B&S. There was tremendous rivalry between Johnson and Yazoo.
Both Johnson and Yazoo are out of business now, although I thing their names are used by other companies.
Most of the parts are generic or can be built by a good welding or machine shop.
When my folks moved into a new house in 1950, the weeds were knee-deep. My dad hired a guy with a Yazoo to mow the grass. He also killed several snakes with the Yazoo.
Thanks for sharing some of the company history...
It is the most solid mower I've ever seen...
Over the years I've ruined two decent Honda Powered Mowers... both hit something in tall grass... once I was helping a friend and another time I let someone from work use my mower... both times the crank was bent and the vibration was terrible.
At least with a mower like the Yazoo... the motor is isolated from the blade by belts...
Yesterday... my sister in law was asking me how to get rid of it... I probably should have offered to haul it away.
My nature is take a little closer look plus it was very rewarding to fire it up and hear how well it runs...
   / Yazoo S-26 High Wheel Mower awakens! #4
I took a closer look at your picture. That mower is in great shape! It is relatively new. My guess is was built around 1990. My Johnson was built in 1989.
The mower that cut our grass in 1950 did not have that sissy skirt around the blade. It had a top deck, but no side skirts. Most of the older mowers had Clinton engines.
As I recall Mr. Johnson worked for (or was a partner) in the Yazoo Company. Mr. Johnson held the patent for the drive unit and he split off into a separate company.
I figured it was a later model with the composite yellow wheels...
2020 JCB 930 ROUGH TERRAIN FORKLIFT (A45046)
2020 JCB 930 ROUGH...
2011 LONE STAR UTILITY TRAILER (A45333)
2011 LONE STAR...
2015 WESTERN STAR 4900 SF (A45333)
2015 WESTERN STAR...
2014 Mazda 6 Sedan (A42744)
2014 Mazda 6 Sedan...
PT PTO Driven Canal Pump (A44501)
PT PTO Driven...
HONDA EG2800I INVERTER GENERATOR (A45333)
HONDA EG2800I...
