Yay, another new problem - high pressure feed line to the loader valves is leaking
   / Yay, another new problem - high pressure feed line to the loader valves is leaking #1
KrisHansen
Vermont
New Holland TC33d
Where the hard line attaches to the distribution block hydraulic fluid is spraying out from the sleeve under the nut on the fitting. It is as tight as can be. The sleeve is stuck to the nut too.. I'm guessing it's not possible to fix this, as any attempt would make it too short most likely. Sigh.
Replaced the (red) hard line. As well, both filters. Much better.
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2011 New Holland Boomer 90 MFWD Utility Tractor (A52748)
2011 New Holland...
2019 Ford Fusion Sedan (A50324)
2019 Ford Fusion...
2011 Nissan Maxima Sedan (A50324)
2011 Nissan Maxima...
Electric Golf Cart (A50121)
Electric Golf Cart...
