Yardman tractor will not turnover
/ Yardman tractor will not turnover #1
mikefrommichigan
Hi everyone.
Just acquired a Yardman tractor with a 16hp kohler command.
I got it home, unloaded it from the trailer and started cutting grass. I was cutting some longer grass and after approx 10 mins the engine labored and I was unable to put it into neutral before it stalled. I raised the deck, placed the transmission in neutral depressed the clutch pedal turned the key and nothing. It did not turn over. I also noticed that the ignition light did not come on when the key was set to start.
I thought maybe it was a fuse, so checked the 20 amp fuse under the transmission plate, but that was ok.
The previous owner did mention that he disconnected the seat safety years ago and has nothad a problem.
Any help would be appreciated to get it started again
/ Yardman tractor will not turnover #2
Sounds like a switch problem, seat, pedal check them first. Is it hydrostatic? If so it should have a switch for that as well. You didn’t happen to leave the deck on while trying to start it?
Thanks. It is hydrostatic. I made sure the deck was in start position. I will go and check again this evening
FORD F750 BUCKET TRUCK (A65054)
FORD F750 BUCKET...
2022 EZ-GO ELITE...
2015 Chevrolet Express 2500 Cargo Van (A61573)
2015 Chevrolet...
New/Unused Wolverine 84in Dozer Blade/Snow Pusher (A65583)
New/Unused...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2017 BX2680 Sub Compact Utility Tractor (A63688)
2017 BX2680 Sub...
