Yanmar YM2000 Hyd ?
   / Yanmar YM2000 Hyd ? #1
FixableUnknown
I have a YM2000 grey (the pea green model) and have some questions about remote hydraulics. I have a Bush hog FEL QT 1846. I understand I can use the power beyond port from the FEL control valve to setup my remotes. I have searched and read many post but have a few unanswered questions.
1. Do I have to change the fitting in the picture to activate the power beyond feature? I spoke with a guy at Bush Hog who was very vague on how to hook this up.
2. Will a standard log splitter open center valve work with this setup?
3. Where do I connect the return line?
4. When the lines are not being used, do I need to hook them to each other to form a loop?
I will also post this in the Hydraulic group.
Thanks, Chris
picture.php
picture.php
Problem solved! The guys on the hydraulic forum came up with a solution. The high pressure line was already split due to my FEL. I found the line that exits the loader control that goes back into the high pressure line going to the 3 point. I put a QD on this line and connected it to the in port on the wood splitter valve and the out port line went back to the original spot where the loader valve connected to the high pressure line for the 3 point. Everything still works like it did before.
2017 Isuzu NPR Crew Cab Landscape Dump Truck (A48081)
2017 Isuzu NPR...
2008 John Deere 9570 STS Combine - Front Duals - Premium Cab - 1,704 Sep Hours - Clean & Field-Re... (A50397)
2008 John Deere...
2022 Chevrolet Tahoe SUV (A48082)
2022 Chevrolet...
2016 Kia Cadenza Sedan (A48082)
2016 Kia Cadenza...
2014 Ford Escape S SUV (A48082)
2014 Ford Escape S...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
