Yanmar YM1601D Light Bulb Problem (charging indicator light)
   / Yanmar YM1601D Light Bulb Problem (charging indicator light) #1
frankmako
Bronze Member
North Georgia
Ford 4610, Ford 3910 and YM1601D
I need to change out a blown light bulb in the panel of my YM1601D. The charging indicator light does not come on when I push the check button. What type of lamps/bulbs do they use?? How do you get to the lamps??
Frank
   / Yanmar YM1601D Light Bulb Problem (charging indicator light) #2
On my 1610D, the charge light would illuminate when the key was in the run position, with the engine in the off position. You should be abled to reach the bulb by removing the access panel in front of the shifter handle, although it's a bit of a twisted reach in and up.
   / Yanmar YM1601D Light Bulb Problem (charging indicator light) #3
How many TBN'ers does it take to change a light bulb? :D :D :D
Frank, I don't know your answer. The bulbs used on 70's Yanmars are proprietary, and are only available from the aftermarket parts people who post here occasionally. I don't know if Yanmar continued that odd bulb up into your years.
2013 Jeep Patriot Sport 4WD SUV (A53424)
2013 Jeep Patriot...
2020 CHEVROLET SILVERADO TRUCK (A51406)
2020 CHEVROLET...
2014 CATERPILLAR TL642C TELESCOPIC FORKLIFT (A51246)
2014 CATERPILLAR...
Set 4- 12-16.5 tires/wheel for bobcat (A53421)
Set 4- 12-16.5...
2025 Future 72in Log Grapple Skid Steer Attachment (A53421)
2025 Future 72in...
2016 Ford Fusion Sedan (A53424)
2016 Ford Fusion...
