Yanmar YM1500 clutch not fully disengaging
   / Yanmar YM1500 clutch not fully disengaging #1
thahn1608
I have a Yanmar YM1500. Ordered new brakes and seals to deal with the oil leaking into the brake drums, now I'm ready to tackle the clutch issue.
The clutch doesn't fully disengage. I adjusted the pedal and there is still more adjustment to go, but when I push the clutch in it just keeps kissing the flywheel so getting into gear can grind unless I just jam it in quickly. If the transmission is in first gear and the clutch is in, when I take my foot off the brake the tractor wants to inch forward.
The tractor show 297 hours which I believe. It has been garage kept all its life - you can still read the factor paper stickers on the loader cylinders and the tractor is in immaculate condition.
Am I looking at replacing the clutch? Is there a quick check or a trick that doesn't require splitting the tractor? I'm not 100% familiar with these so I'm asking for help from people who are smarter and/or at least more experienced than me.
   / Yanmar YM1500 clutch not fully disengaging #2
You should have appx 9/16 to 5/8" free play at top of pedal. Is that what you have?
That is what I have. The pedal barely moves before resistance.
   / Yanmar YM1500 clutch not fully disengaging #5
On the YM1500 You have besides the clutch shaft bearings, bushings on the Main Drive Shaft. 2 Clutch lever Bushings on a Clutch Pedal shaft that goes through the Trans. just behind the Bell housing.
The Main Drive shaft. RED Ym1500 Only uses the Main drive shaft TS-213. And CB-4190 Clutch lever Bushings I was referring to.
Make sure your pedal is moving correctly and not a problem. If it is Clutch is most likely stuck. My ford 2000 the clutch was stuck to the pressure plate. Actually a 2 stage so 2 disks on it. That had to go to the Equipment repair shop!!
Feteral 10"x60' Transport Auger (A50774)
Feteral 10"x60'...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
1996 Fiat Allis FG 65C Motorgrader (A51573)
1996 Fiat Allis FG...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
Selco V5-HD Vertical Hydraulic Baler (A51691)
Selco V5-HD...
