Yanmar YM-240 Engine problem
   / Yanmar YM-240 Engine problem #1
CEY
I have a question related to the engine on this tractor. It is a 2 cyl. diesel, and I purchased it cheap because the previous owner claims it was overheated, began to labor and he shut it down, and thinks it spun a bearing. It has been run several times since, and the engine does not show any signs of a bearing that is spun and siezed. What it does while it's running is idle rough/irratic, and after running a minute or so, seems like it starts to labor. After shutting it down, the crankshaft turns easily, so the laboring doesn't seem to be a result of the bearings. I did notice that while running, in one spot between the head and block there is oil that seems to bubble in and out during compression strokes on the rear cylider. This leads me to believe it is a blown head gasket from overheating. The question I have is if anyone knows whether a blown head gasket would produce these symptoms:
Hard starting
Rough idle
Laboring after warm up (1 to 2 minutes after starting)
Any feedback is greatly appreciated.
Thank you.
CEY
He said he was rough mowing with it, and after it overheated, he looked at the radiator and it was plugged with fuzz.
   / Yanmar YM-240 Engine problem #4
Have you run the engine with the radiator cap removed. Just wondering if it is losing compression into the cooling system.
Does the oil look milky?
There seems to be a bit of pressure when the radiator cap is removed after idle for about a minute, I drained some oil out and there is no coolant in the oil. Coolant level is not down, at least that can noticed. Seems to be some pressure in the crank case, either due to blow-by or because the head gasket is leaking compression into the oil channel. I don't think it is blow-by, the tractor only has 671 hours.
2017 JOHN DEERE CP690 LOT IDENTIFIER 180 (A53084)
2017 JOHN DEERE...
2011 Jeep Wrangler Unlimited 4x4 SUV (A51694)
2011 Jeep Wrangler...
(APPROX 250) UNUSED LANDHERO 30" TRAFFIC CONES (A51248)
(APPROX 250)...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
UNUSED FUTURE FT380 STAND ON SKID STEER (A51247)
UNUSED FUTURE...
