Yanmar vs Kubota
   / Yanmar vs Kubota #1
Terrydt100
Weatherford okla
Iseki & ford,1210
Am looking for a used 16 to 18 hp 4by4 for a small,acreage. If you were me which would you buy? I know every one has their own opinion on this subject . Just trying to get some feel from owners.yanmar seems to be a little cheaper.
   / Yanmar vs Kubota #2
My thought would be a Kubota-not because I own one, but because I imagine parts and support may be easier to find.
Will
   / Yanmar vs Kubota #3
Ditto on Kubota
How close is the nearest Yanmar dealer?
My rule of thumb is, the more expensive an item is, the longer I intend to keep it. If a Yanmar is $900 and you could junk it if it gave problems vs. a $4000 Kubota, then perhaps the Yanmar.
I have had my Kubota 15 years and expect 10 more.
Id prefer a used kubota vs a new tractor from Northern equipment, even at the same price.
   / Yanmar vs Kubota #4
Kubota. I have never had any trouble out of our Kubota tractors.
   / Yanmar vs Kubota #5
My thoughts - If you're mechanically inclined and don't mind working on your equipment yourself, you might consider a Yanmar, they're good solid tractors and parts are fairly available (for certain models) from Hoye's Tractor Parts. https://www.hoyetractor.com/
Read some of their notes on the left side of the homepage, they even list some models to avoid because of the lack of parts.
Fredricks sells reconditioned Yanmars, with a warranty and they also have parts. http://www.fredricksoutdoor.com/yanmar/
Both are great people to deal with and stand behind their sales
If you're the kind of person that would rather have your repairs done by someone else, then consider the Kubota, since they have dealers all over the place.
I'd not hesitate to buy a Yanmar from Fredricks but then again, I like to work on my equipment.
That being said, I had my older Kubota for 10 years and other than fluids and filters, I only spent about $50 on parts for it during those ten years.
   / Yanmar vs Kubota #6
Kubota over the years turn out some tough B models,and you still can get parts plus info.
   / Yanmar vs Kubota #7
Thomas you're right and I forgot to mention that my old Kubota was very used when I bought it.
   / Yanmar vs Kubota #8
Previous tractor was a Yanmar FX24D, current tractor is a MF GC2400. The BIG DIFFERENCE is the MF has a factory front loader. I built a loader for the Yanmar. Neither caused any problems other than routine maintenance. BUT, the 30+ YO Yanmar did drop a valve and crack the block. Sold it to a machinist who I believe is still using it after sleeving the cracked cylinder.
Timing on the break down, heavy Spring cutting season, is what made me replace the Yanmar. Otherwise, I would have just replaced the engine and been still using it.
   / Yanmar vs Kubota #9
both could be crap if the used engines been abused, start them both when cold listen for noise and oil burn
   / Yanmar vs Kubota #10
I have a little Yanmar 2wd that is just a keen little tractor. But you have to understand its also a simple little tractor and not try to make it do more than it was intended to do. My Kubota is also old but more capable. Its more fun to operate the Yanmar and it just likes to startup and go. My Kubota is more of a sleepy head but just fine once it wakes up.
Both offer new tractors with much friendlier "offices" but just too expensive unless you have a commercial interest that makes it pay to have it.
Newton 60 Truck-Mounted Sprayer  850 Gallon Tank  Raven Controller Included! (A44789)
Newton 60...
Heavy-Duty 4-Wheel Rolling Warehouse Cart  74in x 32in (A44789)
Heavy-Duty 4-Wheel...
2020 Terex RL4 4000W Towable Light Tower (A44571)
2020 Terex RL4...
AGT YSRT14 Stand On Mini Skid Steer (A44501)
AGT YSRT14 Stand...
1999 Progressive Industrial Barge (A44571)
1999 Progressive...
2013 FREIGHTLINER CORONADO 122 SD (A45333)
2013 FREIGHTLINER...
