Yanmar tach
   / Yanmar tach #1
roon
oklahoma
NH TC40DA & YANMAR 3110
Ive got a ym3110 and the tach does not work. I have a tach off of a saild rail and its brand new so I was thinking about putting it on the tractor but didnt know where to start on a diesel motor since it does not have a coil to splice into. Any ideas?
   / Yanmar tach #2
The tach on your Yanmar is a mechanical tach with a drive cable (like a speedometer cable). More than likely, this cable is broken. A new one is available from Hoye tractor, is inexpensive, and easy to install. I would do this instead of trying to install an electrical tach. Also fixing the existing one keeps the hour meter working properly. The hour meter on these tractor are not hour for hour unless you are running the tractor at full pto rpm.
   / Yanmar tach
Thanks for the info! I have a muffler and manual on order from hoye right now.
   / Yanmar tach #4
Mabye just a broken cable. You can follow the cable all the way to the tach
   / Yanmar tach #5
The cable might be ok and just need to be tightened. I had mine worked on a while back and the mechanic didn't have one end of the cable inserted correctly. The tach worked fine after I checked it.
sewer tank (A52377)
sewer tank (A52377)
2015 UTILITY VS2RS 53FT REEFER TRAILER (A54607)
2015 UTILITY VS2RS...
2012 JOHN DEERE 644K WHEEL LOADER (A52705)
2012 JOHN DEERE...
2022 Forest River Cherokee Grey Wolf 26BRB Patriotic Edition 32ft. T/A Travel Trailer (A51694)
2022 Forest River...
Online Buyers Premium (A47477)
Online Buyers...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
