Yanmar RFM PTO rpm (YRM48)
   / Yanmar RFM PTO rpm (YRM48) #1
JCByrd24
Midcoast Maine
John Deere 2320
Anyone out there have a Yanmar YRM48 (or other size) rear finish mower and a manual for it, or do you know what PTO speed it is supposed to be run at. I've been running mine at 540rpm based on guidance from JD dealer I bought it from last year (with my 186d). For no other reason than curiosity today I calculated the blade tip speed and found that it looks like I want 1000RPM PTO. I don't really use it to mow the lawn so I haven't found that it doesn't cut properly. I have about an acre of old hay field that I mow with it around 4-5" once or twice a month, and it does that with decent results at 540rpm, but it could be better. To be clear it's basically grass now, only about 8" when I cut, and it's not really working the mower or tractor at all. Now that I think about it the mower doesn't really sound like a mower either, the airplane taking off sound when the blades engage, just the whirl of the belts and gears. Here's my math...my understanding is 18000-19000 fpm or just over 200 mph tip speed is "standard".
17" blade x pi = 53.4" = 4.45 ft circumference or ft per revolution
540 PTO rpm x 4.25 gear/belt ratio = 2295 blade RPM (I counted the ratio)
2295 rpm x 4.45 ft = 10213 fpm tip speed or 116 MPH
Now, 1000/540 = 1.85
10213 x 1.85 = 18913 fpm or 215 mph, which tells me this mower was designed to run at 1000 PTO rpm.
Thanks for the reply, I agree it seems very slow. If the numbers didn't seem to indicate that 1000rpm PTO was PERFECT, I'd question it more. I had also noticed that the woods smaller sizes are about the slowest of today's mowers. The 60 and 72 over 18000+fpm. A user here has a manual and hopefully will be getting home from a trip today and look it up for me. I'll report back.
   / Yanmar RFM PTO rpm (YRM48) #4
Give Gary Jamieson at Jamiesom Tractor a call. He'll know or be able to look it up.
   / Yanmar RFM PTO rpm (YRM48) #5
Read the manual I have for the YRM-48 and there is no mention of what rpm to run at all??
But just read my YRM 48A manual and it says 540 rpm.......
Gary will know.
2016 INTERNATIONAL LF687 (A53843)
2016 INTERNATIONAL...
Informational Lot - Shipping (A53473)
Informational Lot...
Two Post Car Lift (A50120)
Two Post Car Lift...
2015 PETERBILT 365 (A52472)
2015 PETERBILT 365...
2018 Caterpillar CS54B Smooth Drum Vibratory Dirt Compactor (A51691)
2018 Caterpillar...
JOHN DEERE 3020 TRACTOR (A51247)
JOHN DEERE 3020...
