yanmar question
   / yanmar question #1
jonboy1981
just bought my frist tractor it has a decompression lever on it what is it for? all so what should the temp run on this tractor its a 2200
   / yanmar question #2
Used to ease starting as the engine turns over easier without compression. I use mine every time I start mine. Hold decompression lever and crank until oil pressure builds. Release lever and start. If you use it every time may also prevent engine damage if for some reason you have fluid in the cylinders at startup.
2019 Allmand Bros Maxi-Lite II S/A Towable Light (A52377)
2019 Allmand Bros...
Gravely Pro-Turn 460 60in Zero Turn Mower (A52377)
Gravely Pro-Turn...
2021 ONYX RX34 ELECTRIC SWEEPER (A51406)
2021 ONYX RX34...
RIGID 141 THREADER (A53843)
RIGID 141 THREADER...
2012 UNVERFERTH 10-INCH FRONT WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
