Dealer Yanmar model and dealers?
   / Yanmar model and dealers? #1
Justin Dine
SW Missouri
looking for one
I'm trying to figure out what model I need. I've got just over 4 acres of hilly terain so I know I need a 4x4. I need a loader (just got 30 tons of dirt delivered and its really hard shoveling it) tiller, brush hog and a rear blade. In the future I would like to get a finish mower and a backhoe. I've been looking at the 15XXD and the 16XXD but I'm not sure about any stability issue especially with a loader. Also I've been looking for a dealer near here (SW Missouri) and I've been unable to find one. The closest I've found is one in OK (Tractor Yard in Coweta OK) but he is dealing with recons. and I'd hate to drive several hours and then get junk. I don't want to start an argument over recons or not recon just looking for experiences.
   / Yanmar model and dealers? #2
Justin, you touched on one of my pet subjects, putting a FEL on a Yanmar. Most were not designed for use with a FEL.
I do have an FEL on my tractor and I spent a fair amount of time thinking about how much can I pick up without breaking anything. To my surprise after doing the engineering thing the answer is not much without exceeding some ratings.
I've done the calculations, weighed the tractor (4000#) front and rear, looking at rated tire capacity and tried finding data on front axle rating (without any luck).
After the dust settled so to speak, my tractor with the FEL, filled rear tires and just me setting in the seat, my stk front tires has ZERO reserve capacity to carry anything. Weight transfer is far more than I expected. Every pound placed in the bucket placed 2# on the front axle. The rated capacity for the FEL >2000# but that doesn't matter as it is not the weak link in the set-up.
Knowing that, I have picked up way more than I should and so far no failures but at least I know I'm running on borrowed time so to speak any time I pick up a substantial load. I've picked up what I'd estimate was 800# without failure but the rear axle was pretty light and tires looked half flat.
I'm not saying not to put an FEL on the tractor or pick up a substantial load but I am saying to be safe you need do as I did, do the math, weigh the tractor and KNOW what a safe load is for the machine you get.
   / Yanmar model and dealers? #3
Find a dealer you trust then use the dealer to help you hone in on the right unit for your needs. Plenty of dealers names can be gleaned from posts here and elsewhere. GET REFERENCES from who ever you consider. If they can't/won't provide references, move on. We get calls routinely from people who bought pretty trash that quickly turned into an expensive lawn ornament. They always have lots of reasons they bought what they did, but I always ask them if they checked references and in these cases I have NEVER had someone say "Yes, I did, and the references were all (or mostly) positive." I am convinced this is the #1 thing you can do to protect yourself in making such a purchase.
   / Yanmar model and dealers? #4
I'm trying to figure out what model I need......hilly terain so I know I need a 4x4. I need a loader ,... tiller, brush .....a 15XXD and the 16XXD but I'm not sure about any stability issue especially with a loader. ........I'd hate to drive several hours and then get junk...
I've had a 1610D for awhile and a 2010D for a couple hundred hours, used in very hilly, rocky terrain. Both with Koyker loaders, an 80 & 125, respectively.
I second MickeyFX's view on the (over)loading and technically unsafe use of loaders on these yanmars, but I have observed that these machines are very finely engineered and made, and are overbuilt to a significant degree.
I do not find that these loaders are overpowered by the tractors, nor were they underpowered. I always keep 450-500 Lb on the three-point (RC or BB) so I've never felt dangerously off balance with any load that I could lift. MY curl on an overweight load (one I couldn't lift) would lift my rear slightly, but not the raise cyl. I have some very steep grades, and I have moved many tons of rock and dirt, sometimes surprisingly loads that I would estimate to be at or in excess of 1000 lb. (with the 125 on 2010D)
I will say the stock tires on either 1610 or 2010 were clearly the limiting farctor in the immediate safelty of operating with near or at lift-capacity loads. When operating with the oem tires, firestone or the chinese MIT, I felt dangerous with any more than a few hundred #. I ran the tires with 17-19lb, and was worried that a tire would blow when carring weight across sharp rocks or brush. A sharp-cut sapling took out the MITs on my 2010, and I got a pair of thai brookstone 6.00-14s, which are close to 6-14s, but a little heavier (6PR) and have a slightly larger rolling dia (I forget 3-5" or something) They are rated to run at a max of 46 PSI and 600# higher cap each. There is no doubt that the arrangement is (or feels) much safer. Little tire bulge, unless at max lift, and then there is very little flex. I run them at 36 psi. I try to avoid using 4wd due to the overlead on the front. I engage 4wd only in loose or slippery stuff. I plan on getting larger rears to get closer to an accurate leade match for the front (6%?) but there's too much tread left, the tires are pricey and I feel that I am not overloading the lead ratio too much. I find I can use the Diff lock with almost as much effect as 4wd, but I don't shy from using 4wd either.
I think FEL overloading is a very valid concern, as clearly stated by MickeyFX. I can echo his findings, as done with rough math on my YMs, but my only baseline for reference was the oem tire max capacity. I share the concern that the front end is overloaded. I feel as though the tires were the weakest link in that chain, but I sure don't want to rebuild a front end if I don't have to.
I have been very impressed with the design and capability of these Yams, and they appear to be very conservatively designed and built. I use mine well and thouroughly, doing work that I would not have thought possible. The small frame and compact form allow me to get into the heaviest brush and dense woods prevalent in these parts, and the only lack of safely I have experienced is due to inexperience and poor judgement in my part. I am certain if I ever have a catastrophic failure, it will be due to these factors, rather than any probability of failure on the part of the Koyokers or the Yanmars.
I would say your worry about getting junk can be applied in any market involving high value used equipment. There are a lot of diamonds in the rough out there, but one has to choose very carefully. Go over any prospective purchase with a magnifying glass and operate the unit extensively in every possible mode and operation prior to parting with your dinero.
   / Yanmar model and dealers? #5
I when and got 200 T post try to take them off the trailer . The loader would pick them up easy . but the tractor like to have when over on it's side .And I was just going to back up and sit them down. The ground was flat, Mickey FX is right you can pick up a load but not a big load .And if some one knows how I want them to show me.Don't get me wrong I like my loader I just can not do what I wanted with it.
   / Yanmar model and dealers? #6
I when and got 200 T post try to take them off the trailer..... I like my loader I just can not do what I wanted with it.
Hey, Gizmo36 - Do yo have anything on your 3PT hitch to offset the weight of your FEL & load? Or are you carrying ballast /wheel weights? I don't do ballast or wheel weights, but I try to keep my BB on the 3PT hitch - (450#)i've found with BB on, I can safely carry any load I can lift, on flat ground.
   / Yanmar model and dealers? #7
Hope our comments haven't run Justin off. Yanmars are a great tractor but we need to be aware of some of the limitations when it comes to an FEL. I still have the stk 4 ply tires and I know I'd be better off replacing them with 6 ply tires. Better yet I'd prefer to replace all the stk tires and go with some R4's but that would mean replacing the rims as well. Heavy loads in the bucket aren't frequent enough to justify the expense.
2002 Enclosed Cargo Trailer (A52377)
2002 Enclosed...
2016 Big Tex 14LX 14ft 7 Ton T/A Dump Trailer (A50322)
2016 Big Tex 14LX...
2005 CHANDLER 500 BBL FRAC TANK (A53843)
2005 CHANDLER 500...
MISC PALLET (A53843)
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A53422)
2011 Ram 1500 4x4...
FORD F750 XL SUPER DUTY TRUCK (A51406)
FORD F750 XL SUPER...
