California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 15,029
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
I've been tinkering to get a neglected but fundamentally solid 20 year old Yanmar back into top condition. When I bought it the seller demonstrated 'easy starting' which included slow cranking then lots of poorly burned exhaust smoke in the first 10 seconds. At least it had a new starter and the compression seemed tight and even.
Also the infamous "Yanmar Hammer" (fuel knock, especially loud on 2 cylinder Yanmars) seemed overwhelmingly loud below 1800 rpm cold and persisted down to 1300 rpm warm. The seller said it always sounded like that in the year he owned it. Everything I've read says "they all sound like that".
I replaced the battery which fixed the slow cranking, but the sooty startup and the fuel knock still seemed to deserve attention. I read everything I could find here on fuel quality and fuel knock. It ocurred to me the tank likely held summer diesel several years old, since I was told the tractor was infrequently used as a loader in the past several years.
So I experimented putting 50% lamp kerosene in the fuel filter bowl. This lamp kerosene is also old, part of Dad's stuff I am gradually clearing out of the barns. It looked clean but I filtered it through coffee filters anyway. This seemed to start easier and smoked a lot less but still had the same overwhelming fuel knock sound.
I made up a second test batch of 60% lamp kerosene, 40% red diesel from the tractor's tank, and Power Service (white bottle) at the label recommended maximum strength of 1:200. (A blunt plastic hypodermic from an inkjet refill kit was just right for measuring 5cc per quart/liter of test fuel).
Wow - what an improvement! The tractor started instantly like a new Mercedes and idled cleanly. No soot. Fuel knock was nearly gone and it would idle down to almost 800 rpm cold without much clatter.
Thanks to Bird and others who have posted recommending Power Service! I've always thought fuel and lube additives were snake oil but in this case the cetane improvement (and maybe some other magic in Power Service) were exactly what I needed to make this fuel usable.
I have a few gallons of kerosene and several quarts of first-generation 2 cycle oil in the barn that I was going to take to the county hazardous waste collection. Any advice on blending this stuff with Power Service to use as diesel fuel? I have already installed a fresh fuel filter element and also a pre-filter (a cheap auto gas line filter in front of the real fuel filter) so I don't think particulates are a big risk. Reading about biodiesel, it seems that anything that will go through a filter is usable for diesel fuel if it has sufficient lubricity and the cetane is improved by additives into the recommended range.
Any comments welcome. Blending unorthodox fuels may start a little discussion!
