Yanmar FX20D drive inoperative
   / Yanmar FX20D drive inoperative #1
kuhlhoff
Tallahassee, FL
Yanmar FX20D
New member here, I was brushcutting today (I only have 10 hrs on my tractor) when the tractor just stopped, the FEL works great , the 3pt Hitch works great, engine runs great. It just won't go, all gears the same. I think the clutch went, the clutch had been making some high pitched sound for the last few hrs, went away when the pedal was depressed. Seems odd to just stop though. Any ideas? Next weekend I'll have to ***-along the beast back onto the trailer to get it repaired. I have a repair manual on order.
   / Yanmar FX20D drive inoperative #2
High pitched sound, goes away when depressing the clutch, no clutch now. Sounds like a throw out bearing.
Yeah, but doesn't that imply the clutch would still engage, it would just not disengage? The throwout bearing is only there for the clutch arm to push on the release arm and disengage the clutch disc. Thanks for the reply.
   / Yanmar FX20D drive inoperative #4
Definitely sounds like the clutch. You will have to split it to assess the damage. If it's only showing 10 hours, there's no telling how many hours it actually has.
   / Yanmar FX20D drive inoperative #5
ummm..............yep /forums/images/graemlins/grin.gif
Where was my head??
   / Yanmar FX20D drive inoperative #6
It may be the clutch, I had one go when a friend was using the tractor and he swore he had just parked it and when he got back on it would not move. Try to adjust the clutch pedal to the proper setting where there is about 1/2 inch of play before it starts engaging the clutch. This may let you drive the tractor out instead of pulling it out. Also check to make sure that it is in one of the gear ranges and in gear.
   / Yanmar FX20D drive inoperative #7
</font><font color="blue" class="small">( ummm..............yep
Where was my head?? )</font>
Clutch center could have seperated?.. that's what you were thinking right? /forums/images/graemlins/smirk.gif
Soundguy
   / Yanmar FX20D drive inoperative #8
Boy I'm glad someones watching my back /forums/images/graemlins/grin.gif
   / Yanmar FX20D drive inoperative #9
Inspector.. check this out... We regged within a day of each other and have virtually the same number of posts!
Soundguy
2001 John Deere 670C Motor Grader (RIDE AND DRIVE) (VERY NICE) (A50774)
2001 John Deere...
1988 Comptank Tanker Trailer (TITLE DELAY) (A50774)
1988 Comptank...
P.T Industrial Cart (A50121)
P.T Industrial...
2015 Harlo HP8500 Forklift (RIDE AND DRIVE) (A50774)
2015 Harlo HP8500...
2015 Peterbilt 579 (A50120)
2015 Peterbilt 579...
2001 Ford F150 (A50121)
2001 Ford F150...
