Yanmar FX20
   / Yanmar FX20 #1
nazeer4
Washington
Yanmar Fx20D
Hi, I am totally newbie to tractors. I just bought a used Yanmar FX20D. I have two questions
1. Looks like I need oil change - can someone please tell me what type of oil and other fluids I should use.
2. The coolant tank rusted inside and the pipe is hanging without connecting to anything. Do I need to replace the tank?
Thank you for your reply and any help
   / Yanmar FX20 #2
Many of the older tractors use 15W-40 oil. It seems to be formulated for diesel engines. I have no idea what oil filter you need, though. You should be able to read the numbers on the existing filter and get a cross reference to something common. You may not find an owner's manual for the fx 20. Surfing I got the distinct impression it's a grey market tractor. From doing a bit more surfing I found the YM276D is probably the closest equivalent. I have a grey market Mitsubishi and believe me, you have to get a bit creative to keep them going - but you can keep them going. I don't know what you mean by coolant tank. Are you inquiring about the overflow catch tank or the top of the radiator? The radiator's kind of critical. Many older tractors do not even HAVE an overflow tank. Yes, it should be secured but you can use almost anything as a replacement.
   / Yanmar FX20 #3
Likely to be differing opinions on gray market tractors but it's a good way to get started in tractors without a bale of spending cash. That yanmar can be a hard worker. I hope this info helps you.
For oil & fuel filters use the easiest way you can - forum/web /manufacturer. Hopefully someone on this forum or the yanmar forum has cross ref info to share, but if not try online searches and filter mfg to see if they might cross ref to the yanmar filter. Don't forget your Napa auto parts stores as a resource - not sure if this is in all areas but around here Napa has their own tractor filter reference on their computer and sometimes they can connect the tractor filter numb to another filter that will work. For hydraulic filters try the filter mfg as well - by looking at filter spec manuals (usually on their web sites) you can figure out size & fit, flow & pressure spec, bypass, temp, particulate rating, etc. (You may need to measure your filter o-ring seating dimensions when picking a cross Ref filter)
It's nice to have a cross-reference chart but not always avail.
For hydro oil, suggest a good quality middle range oil suitable for the temp range in the locality where you will be operating, i.e. you wouldn't use the same oil in winter in fairbanks that you would use in dallas - but if you are just operating in summer you might be able to use same oil in both places. I would pick an oil that works for my entire operating range if possible. All hydro oils have operating specs and you can review & select the "blend' (additives, temp range, etc) that works for you in your locality.
Water - Tractors live in environments high in condensation. The average farm tractor is run enough to probably get thru this OK, but if your equip sits for long periods you could see more moisture in oil.
Best of luck with your tractor/Regards
2025 Swict 84in Bucket Skid Steer Attachment (A53421)
2025 Swict 84in...
1269 (A50490)
1269 (A50490)
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2013 INTERNATIONAL 7500 SBA 6X4 DUMP TRUCK (A51406)
2013 INTERNATIONAL...
2019 KUBOTA SVL95-2S SKID STEER (A52705)
2019 KUBOTA...
2016 TAKEUCHI TL8 SKID STEER (A51242)
2016 TAKEUCHI TL8...
