YANMAR F18D ELECTRICAL PROBS
   / YANMAR F18D ELECTRICAL PROBS #1
PEAR TREE
NEWNHAM ON SEVERN
YANMAR
HELP I WENT TOSTART IT YESTERDAY AND THE BATTERY WAS LOW SO I TOOK THE BATTERY OFF CHARGED IT AND PUT IT BACK ON. I HAD PROBLEMS WITH THE TERMINALS BEING LOOSE BUT I FIXED THAT, PROBLEM NOW IS GLOW PLUG LIGHT DOESNT COME ON AND DIESEL GUAGE DOESNT COME ON BUT THE STARTER MOTOR WORKS FINE BUT ENGINE DOESNT START.
   / YANMAR F18D ELECTRICAL PROBS #2
Electrical problems, ain't they fun. :)
It still appear you have some bad connections since much of your electrical system isn't working. Now if your F18D is like my F24D, there is an electrical fuel shutoff and I suspect it isn't getting any power either. Need to use a meter and find out where the power stops, i.e. measure across all connections and find where there is voltage or if you test with one of the test leads connected to ground, locate where there is voltage on the input side and no voltage on the output side.
thanks mickey I will get myself a tester.I am still concerned what I did to cause this. Could I possibly have the batteryaround the wrong way? is it a negative or positive ground system?
   / YANMAR F18D ELECTRICAL PROBS #4
Haven't seen a positive ground system in MANY yrs. With a digital meter it's easy to check since they measure both positive and negative voltage.
hi Mickey
Thank you thank you thank you
I stupidly put the battery in the wrong way round
and thats why it wouldnt start
although the starter motor was working.... probably going the wrong way round
You probably realize I am a novice when it comes to mechanics but I do like to have a go
You have a nice day
and a Happy Christmas
Cheers Pete
2017 Nissan Maxima Sedan (A50324)
2017 Nissan Maxima...
2012 CATERPILLAR 259B3 SKID STEER (A51242)
2012 CATERPILLAR...
2007 INTERNATIONAL 7400 DT466 SFA 4X4X CHASSIS TRK (A51406)
2007 INTERNATIONAL...
Adams 8 Ton Weigh Hopper (A52128)
Adams 8 Ton Weigh...
Chevrolet C8500 Flat Bed with a Moffet Kit (A52128)
Chevrolet C8500...
Kuhn SR108 Speed Rake (A50515)
Kuhn SR108 Speed...
