Yanmar eg907 steering issues
   / Yanmar eg907 steering issues #1
aussie simo
nsw australia
yanmar eg907
Hi all, wondering if there are any eg907 owners out there that have experienced notchy steering? Mine started getting bad around the 700 hour mark. I believe the problem is in the angle the shaft takes through the fire wall, there is a bush there with no lubrication point. Problem disappears if you put steering column in lowest position so it straightens out the shaft, just interested to see if this is common problem
   / Yanmar eg907 steering issues #2
I had no idea what an EG907 was so I Googled it....doubt there is even one here in the U.S. That is a beautiful machine, I had no idea Yanmar made 90 hp tractors. (Sorry I can't help with your steering issue)
It is a great machine, has every gismo you could ask for, it is however a compact tractor and as such is quite light and narrow tracked, which makes life a little difficult at times
2012 Chevrolet Silverado 1500 LTZ Crew Cab Pickup Truck (A51692)
2012 Chevrolet...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
RYOBI 3300 PSI GAS PRESSURE WASHER (A51248)
RYOBI 3300 PSI GAS...
2017 CATERPILLAR 323FL EXCAVATOR (A51246)
2017 CATERPILLAR...
2013 JOHN DEERE 8235R LOT IDENTIFIER 215 (A53084)
2013 JOHN DEERE...
1995 INGERSOLL-RAND SD40F PADFOOT ROLLER (A51246)
1995...
