kebo
Elite Member
- Joined
- May 16, 2006
- Messages
- 2,931
- Location
- Lexington, SC
- Tractor
- 2001 John Deere 790 4x4, bar tires
I used to have a JD 750 with a Yanmar indirect injection diesel engine in it. Now I have a JD 790 with a direct injection Yanmar engine. On the 750 the only way to turn that engine off was by shutting off the throttle completely. Turning the key off did not turn those engines off. In fact, on that tractor you could remove the key from the ignition and it will still run. Sometimes when you did shut off the throttle, depending on how hard you had ran it, it would diesel right on which was quite annoying.
Now, on my 790 I turn the key off and it shuts off period. No questions asked (so far). I've only had the 790 for about 3 months now, but have not really used it enough to see if it will diesel after I switch the ignition key off. Is there any chance it could diesel on after turning the ignition off??
Is the difference in turning these two engines off because of the indirect injection versus direct injection?
Or is there another reason for that? As you can tell, I'm not very knowledgeable about diesel engines.
Keith
Keith
