Yanmar Cub Cadet EX2900 gear shift lever just flops around....
   / Yanmar Cub Cadet EX2900 gear shift lever just flops around.... #1
DanF
Texas
Hello guys, hope someone has had/seen/heard about this 1st breakdown on this compact tractor. Its got the hydro trans & I was just driving out 200 yds from the house, stopped, left idleing & went back up to move again & the shifter lever just moves freely...no gear engagement at all. Its now stuck in gear & the gear shift lever has no effect at changing gears...can't even feel anything thru the lever...just an effortless movement. It will not start due to the neutral safety switch seeing it in gear.
Checked the lever to the horizontal shaft going into the trans & the external roll pin looks intact & is moving the horizontal shaft. I can actually pull the shaft/lever out about 1 1/2" till it hit the inside of the rear fender.
Anyone got any ideas? Broke something internally in the trans. I hear theres another roll pin inside the trans.
Also, anyone know where the neutral safety switch is on this thing? Need to bypass to get the tractor closer to the garage/tools.
   / Yanmar Cub Cadet EX2900 gear shift lever just flops around.... #2
If that shaft pulls out that far it definatly sounds like whatever is on the end of that shaft! Can you access the starter? If so leave the ign on and jump the starter to get it running and to your garage at least.
I happen to stumble by & will reply to my own post here. It was indeed a hardened roll pin that apparently vibrated loose ( I guess) on a gear shaft in the transmission. Took several hrs of just getting to it (seat, mounts, hyd lines, etc). Pin was in good condition, reinstalled, staked this time and to this day its still going w/o another incident. Cost: ~$3 in copper washers from NAPA for the hyd lines.
2005 Chevrolet Colorado 4x4 Pickup Truck (A51692)
2005 Chevrolet...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2000 John Deere 1860, 30ft Wide, Gandy Box, Wing Fold, 7.5in Spacing (A52748)
2000 John Deere...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
2017 FORD F-250 SUPER DUTY (A52472)
2017 FORD F-250...
