Yanmar blowby or ?
   / Yanmar blowby or ? #1
JimP
southern New England
Kubota L5460HSTC; Volvo ECR88 excavator; Dresser TD9H dozer; Bandit RM990 chipper (sold)
I looked at a Volvo ECR88 excavator with a four cylinder Yanmar 60 horsepower engine today. The engine is early emissions so it has a sealed crankcase vent rather than a drip tube. 3100 hours and maintenance looked good. It was stored outside and started up in 30 degree weather with just a few seconds of preheat. The engine ran well at idle and higher throttle with no exhaust smoke. BUT - when I pulled the dipstick at idle a lot of oil droplets started blowing out, coating my finger in a couple seconds. Oil droplets also blew out when I pulled the oil filler cap. There was no visible smoke from either the dipstick tube or oil filler and the crankcase vent is sealed. There was a light pulsing over the dipstick tube but no pressure if you put your finger over the tube. The tubes do not leak when closed and there is no other visible oil leakage anywhere on the engine.
The excavator is at a dealer and the mechanic did not believe the oil droplets were due to worn rings or blowby. They were going to check for clogged crankcase vent and do a compression and leak down test.
Any comments on whether this is normal for larger Yanmar engines. TIA Jim
   / Yanmar blowby or ? #2
I'm not 100% sure, but I believe the puffing you felt was normal for a Yanmar engine. I'm not sure the droplets coming out is a bad thing either, but, it sounds good that the dealer is willing to look at it a little closer. If you really want to know what's going on with it, request an oil sample to be taken and sent out for testing, that's the best way to find out what's going on with the motor, the same can be done for the final drives as well.
On a side note, I really like those 88s. I rented one for a month a couple of years ago and was very impressed with it, it is a very responsive and quick machine, surprised I don't see more of them around.
iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A51692)
iDrive TDS-2010H...
2017 Chevrolet Tahoe SUV (A51694)
2017 Chevrolet...
2022 Polaris Ranger 4x4 Utility Cart (A54811)
2022 Polaris...
2010 John Deere LA105 36in Riding Mower (A51694)
2010 John Deere...
Doosan P250 Trailer Mounted Air Compressor (A53117)
Doosan P250...
2018 Infiniti Q50 AWD Sedan (A51694)
2018 Infiniti Q50...
