Yanmar B3
   / Yanmar B3 #1
tarquin2
international 784
Hi, not sure if im posting in the right forum or not, so apologies if im not.
I have a Yanmar B3 360 excavator, which i have used for the last couple of years with no problem. Until yesterday when the track split into one long piece of rubber, I am in the process of orderring a new one, but my big question is - where are the track adjusters? I have been looking for a big nut on a threade bar like i had on another machine but cannot find it. Would it be through the grease nipple?
   / Yanmar B3 #2
tarquin2
Yes, it is a grease nipple in the track frame. You will likely have to unscrew the nipple / adjuster fitting and expel some of the grease to get the new track fitted. Just push inward on the idler after unscrewing the grease valve.
Hope this helps,
Scott@Artec
   / Yanmar B3
Cheers, thanks a lot for that.
1262 (A50490)
1262 (A50490)
2022 Allmond Bros Maxi-Lite II 20kW S/A Towable Light Tower (A52377)
2022 Allmond Bros...
2020 CATERPILLAR 303.5E2 CR EXCAVATOR (A52705)
2020 CATERPILLAR...
2007 Ford F-250 Crew Cab Pickup Truck (A51692)
2007 Ford F-250...
Engel 20' Boat (A50121)
Engel 20' Boat...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
