Yanmar 3TN66UJ what radiator cap to use?
   / Yanmar 3TN66UJ what radiator cap to use? #1
KENSFM
MA
JD 2210 JD318 JD332
I have a JD 332 tractor with a Yanmar 16HP 3 cylinder diesel liquid cooled engine. I would like to replace the radiator cap (I do not think the one that is on there is correct). Would anyone know the correct pressure rating that I should be using for this engine?
Thanks, Ken
   / Yanmar 3TN66UJ what radiator cap to use? #2
I don't believe the engine determines the radiator cap type. You have to consider the whole system, (radiator, hoses, etc.) and use what JD recommends. Why do you think you have the wrong one?
The cap says Stant on it which I believe is an aftermarket brand. The cap is rated for 14#.
Ken
Unused 2025 SDLANCH SDLL30 Mini Track Loader Skid Steer (A51691)
Unused 2025...
2021 Liebherr L556 (A53472)
2021 Liebherr L556...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
15ft. Diamondback Airboat with S/A Aluminum Trailer (A51694)
15ft. Diamondback...
2017 Case SV185 Compact Wheel Loader Skid Steer (A51691)
2017 Case SV185...
