Tiller Yanmar 3pt tiller -- using with Kubota B7610 (and other B-series)
   / Yanmar 3pt tiller -- using with Kubota B7610 (and other B-series) #1
jas67
Platinum Member
Central PA
Kubota B7610 + Kubota G1800-S
I just tried to mount the RS1303 on my B7610, and think I might need longer arms. My hydraulic top link doesn't go short enough to get it at the right angle, and it barely gets off the ground to move it.
Plus, I can't get my slip clutch on and use the PTO shaft that came with it, as there isn't enough room.
I think longer arms may fix all of this. Either that, or weld on new 3PH pin mounts that extend out toward the tractor more.
What have others here done to adapt one of these tillers to work with a Kubota-B, or other small tractor. They ARE designed to work with small Yanmar tractors.
I guess a short top link would work, but that doesn't solve my slip clutch issue. A shorter PTO shaft is out of the question, this one is already pretty short.
Thanks,
Jay
   / Yanmar 3pt tiller -- using with Kubota B7610 (and other B-series) #2
Sorry to here Jay , But it shouldn,t be a problem . The longer arms & shorter top link I would think take care of all the problems.
Do you have any pics of the setup ? Or Measurements of the top & lower links ? it might help figure it out easier . at one time i had 7 , 5 foot Iseki tillers & Several different Lengths of top & lower links . Every one was a little different & just took the right combo to get them hooked up .
On one I had to make an upper link thats only about 6 inches long & hadto Modify the tiller mounts as well. But it was easy enough. Just have to figure it out .
Its just kind of hard to guess the right combo without seeing it & knowing the measurements. But I have cut & added on , or shortened top & bottoms links & arms to make work. Best of luck . Bob
Someone else posted a link for various sized lift arms:
Lift Arms pins bushings tractor Parts
My current lift arms are 23", so the 32" ones should be plenty long to use with my current hydraulic top cylinder, and to also give me enough driveline length to use the PTO shaft that came with it, and a slip clutch.
2013 Ford Expedition 4x4 SUV (A49461)
2013 Ford...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
2019 John Deere 333G Skid Steer (A50657)
2019 John Deere...
KUBOTA M7040 TRACTOR (A51406)
KUBOTA M7040...
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
