Yanmar 3810 oil filter
   / Yanmar 3810 oil filter #1
Ray Dove
Trying to find oil filter for my 3810D other than having to order from Yanmar dealer. Anyone know the USA filters that will fit my 3810D?
   / Yanmar 3810 oil filter #2
You can order from Hoye with some other parts. Or one of us will check our notes and post up the cross over filters. I believe it's the same filter as most of the other Yanmar tractors.
   / Yanmar 3810 oil filter #3
There are several fram filters that will work. I didn't keep my records when I sold mine
You can buy a wix from NAPA, etc, have them look it up for a yanmar 336
Then you should be able to cross the wix to a fram,etc,.
carquest filter #85334 (advance auto parts) may fit your tractor as well
napa : 1568
wix : 51568
fram: ph3593A
Thanks for all the answers. I've written the filters down so shouldn't have to ask next time I change oil.
   / Yanmar 3810 oil filter #5
I looked up my notes.
Here is a few more copy and pasted.
NAPA 1064, 1334, 1344
Fram PH3593A
AC pf1127
Motorcraft FL810
STP s2808
SuperTech at2808
Purorlator L4459
   / Yanmar 3810 oil filter #6
Fram PH3593A
AC pf1127
Motorcraft FL810
STP s2808
SuperTech at2808
Purolator L4459
Basically those are the longer and shorter versions of the near-universal filter that was used on most Subarus and many Nissan and Toyotas etc back when these YM's were made. Available anywhere.
   / Yanmar 3810 oil filter #7
Basically those are the longer and shorter versions of the near-universal filter used on most Subarus and many Nissan and Toyotas. Available anywhere.
I think I have above that that they came from you . I have at the top from California. Not sure it it was a line or two or all of them.
I am pretty sure the modern Toyotas don't have the same filter base to screw on. Cause these numbers are not the same as what I use on my two Toyotas
   / Yanmar 3810 oil filter #8
Ok I'll go back to edit that, to note those filters were common when these YM's were made.
There are minor differences between those numbers, like bypass pressure if the filter is dirty. I don't think presence of a drainback valve is critical if you crank (compression relieved) until the oil light goes out. And there are likely quality differences between brands.
Thanks again to all who replied. Ya'll have been a big help and I have saved all the filter numbers.
   / Yanmar 3810 oil filter #10
I used the Fram PH3593A most of the time, as I usually could find that one at WM and not the other #'s
Tradewinds Power Unit (A50120)
Tradewinds Power...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
NEW Wolverine Skid Steer Pallet Forks Hydro Adjustable (A53002)
NEW Wolverine Skid...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2007 PETERBILT 379 (A52472)
2007 PETERBILT 379...
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
