yanmar 336d clutch
   / yanmar 336d clutch #1
yanmar99
Gig Harbor, Washington
I have a 1987 336d. The clutch will not disengage. I have taken off the inspection plate and can see that the pressure plate is coming off the disc. I sprayed the disc with brake clean. Put the bucket against bank with depressed pedal and spun all four tires. Any suggestions.
   / yanmar 336d clutch #2
Might try going to "search" and type in stuck clutch under yanmar. Good luck!
   / yanmar 336d clutch #3
Lock the clutch lever down and just let it run for a couple of hours at 1500 rpm.
   / yanmar 336d clutch #4
hook up a brush hog, get it spinning and work the clutch a couple times....it has always worked for me.
   / yanmar 336d clutch #5
My 2 cents worth :) the clutch is most likely IMO rusted to the flywheel, so even if the PP is releasing visibly the clutch disc may still have a mechanical connection to the trans thru the stuck disc or else the pilot brg (if it has one?) is frozen thats all it can be one or the other. Keep operating the tractor with the clutch pedal depressed it should free up thats the idea anyway.
This happens to vehicles that sit especially in humid areas, I have seen Yanmars IE my buddys 2820D with a lock mechanism on the clutch pedal that locks the pedal down so this doesnt happen. My 3810D doesnt have it and yours may not either fwtw? hth
   / yanmar 336d clutch #6
My 1610D has the lock down lever for the clutch. If you have one of these after you get it fixed just be sure to lock the pedal down after you shut down to be sure it doesn't happen again.
   / yanmar 336d clutch #7
When I bought my Yanmar, fresh out of the shipping container, it had the clutch latch, but a lot of them had an ornate wooden stick in the tool box especially for locking the clutch down. A lot of guys may have discarded them, not knowing what they were.
PALLET OF SCAFFOLDING (APPROX. 21 PC) (A52706)
PALLET OF...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2015 JOHN DEERE 250G LC EXCAVATOR (A52705)
2015 JOHN DEERE...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
1973 JEEP RENEGADE (A51247)
1973 JEEP RENEGADE...
2013 MACK CXU613 (A53843)
2013 MACK CXU613...
