YANMAR 3110???????
/ YANMAR 3110??????? #1
BLUEBONNET2
harrison county, tx (NE TEXAS)
nortrac 25 xt JD zeroturn 54", briggs mtr.
good afternoon,
while driving around today,i saw this machine and had to stop and look /forums/images/graemlins/grin.gif
yanmar 3110, 967 hrs on meter,shuttle shifter , /forums/images/graemlins/confused.giftried 2 ranges and reverse, worked smoothly: start right up, no smoke, oil was black as night, hydralics work ok for me, look like it had a 3 or 4 speed PTO, just tried 1 range, sounded ok, tires very good, sheet metal looked good, no visible leaks, w/boom pole.....$6000, 5' clipper 500-$550, 5' box---$330..
my question.....what year or years? hp? etc.
he had no VIN number, and said he bought from a wholesaler named fredrick's in georgia or ala. /forums/images/graemlins/confused.gif said the wholesaler" goes thru" all the machine he sales /forums/images/graemlins/confused.gifthe blade and mower are new...
let me know,
bluebonnet2
/ YANMAR 3110??????? #3
I beleive it is about 30-31 HP at the PTO and about 35 engine HP. SOrry don't know much more about it. Looks like a lot of tractor for that asking price but others could give you more details.
Peter
/ YANMAR 3110??????? #6
From the research I did no my YM3110 it was made between 79 and 81.
35hp. with 31hp at the PTO.
Mine works good.
Hope this helps.
Hazmatguy
/ YANMAR 3110??????? #7
Mine works good.
Hope this helps.
Hazmatguy
Welcome, hazmatguy, but you got to check the date on those threads.
/ YANMAR 3110??????? #8
Just a suggestion. Opt for the 4 W.D. & P.S. If he /she has 1
/ YANMAR 3110??????? #9
I also have a 3110D (4wd) with front end loader will carry a 4x5 roll of hay with no problem. I am having oil pressure problems only registering about 15 with the gauge i installed after the idiot light starting glowing. I am not very mechanically inclined but can any tell what the problem might be and how expensive a fix it is (I know hard to say without knowing problem but guesses will help)
/ YANMAR 3110??????? #10
Take out the oil sending unit & see if the oil passage may be stopped up.You may have to drop the oil pan & check the oil pick up tube screen (if it has 1 ) & see if it may be stopped up.
/ YANMAR 3110??????? #11
the passage to the sending unit is not stopped up. if you crank the engine with the sending unit not in place it will sling oil 8 or 10 feet from the tractor, but i have tried two different gauges that read a low pressure.
thanks
/ YANMAR 3110??????? #12
thanks
I feel silly posting to a 3 year-old thread, but I would replace that sending unit.
72''Skid steer bucket (A61567)
72''Skid steer...
Commercial Lawn Mower 652R (A56859)
Commercial Lawn...
1009 (A61166)
1009 (A61166)
2006 Freightliner Auger Truck (A61307)
2006 Freightliner...
2003 International 9200I (A53317)
2003 International...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
