yanmar 240D
   / yanmar 240D #1
maynarga
I have some hydraulic leaks. Whats the heavyest fluid I can get away with?
   / yanmar 240D #2
The heaviest is hy/tran = JD303. You need to fix the leaks, not use heavier fluid, to keep everything working.
   / yanmar 240D #3
"I have some hydraulic leaks. Whats the heavyest fluid I can get away with?"
You arent serious are you? I am just sitting here wondering why ask a question like that. Its not like thicker oil wont leak or something..But anyway welcome to TBN..
   / yanmar 240D #4
I have to say that the oil will have to be thicker than 90wt gear oil because I have a seal where the drive shaft connects to the front diff. that is leaking on my 3110 D .Guess I will just have to replace the bad seal. /forums/images/graemlins/frown.gif
2008 Caterpillar 45kW C4.4 3-Phase T/A Towable Diesel Generator (A51691)
2008 Caterpillar...
2013 Ram 1500 Pickup Truck (A51692)
2013 Ram 1500...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2019 CATERPILLAR 316FL EXCAVATOR (A51246)
2019 CATERPILLAR...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
