Yanmar 240 tranny question
   / Yanmar 240 tranny question #1
ronofohio
My Yanmar 240 2wd, with 8 speed + reverse has a problem with poping out of gear when in reverse. Does not do that with any other gear. I noticed that the shifting rail on the left side of the tranny pops out about 3/4" from the rear of gear box when shifting into reverse. It slides back in when shifting into other gears. There is an o-ring on the shifter rail which also slides out with the rail. The mechanic said that the shifter fork was probably bent and would be expensive. I don't have the cover off yet, but need info. I have a 240 cd, but it is little help. Thanks..Ron
   / Yanmar 240 tranny question #3
I just went out and looked at mine for you. FWIW, a rod does not stick out the back of the transmission cover when reverse is selected.
Like Winston said, if the rod moves along with the fork then there is no detent.
2005 FORD F650 4X2 XL SUPER DUTY FUEL/LUBE TRUCK (A51243)
2005 FORD F650 4X2...
John Deere Bale Spear (A50515)
John Deere Bale...
2019 CATERPILLAR 299D2 XHP SKID STEER (A51242)
2019 CATERPILLAR...
2018 John Deere XUV560E 4x4 Gator Utility Cart (A50322)
2018 John Deere...
2019 Ford F-350 4x4 Crew Cab AutoCrane EHCPRX Crane Mechanics Truck (A50323)
2019 Ford F-350...
HELI STRAIGHT MAST FORKLIFT (A51242)
HELI STRAIGHT MAST...
