Yanmar 2310 down what is it worth?
   / Yanmar 2310 down what is it worth? #1
stumpjumper47
Whitesboro, TX
kubota 4700
Hello,
I have a Yanmar 2310. Has been an exceptional tractor for the 10 years I have owned it. I did a complete rebuild on the engine about 8 years ago thanks to the advice on this forum.
Well the tractor started knocking (sounded like top end) and I got it home and shut it down. Against my gut I started it to move it and it quit.
There is no water in the oil but I have no idea what broke and will not until the engine is opened up.
I am thinking of selling it as is. If so what would be its aprox.worth. I have since bought another tractor and thought about keeping it and fixing it but in reality I do not have the time.
Regards,
Jimmy
   / Yanmar 2310 down what is it worth? #2
If the motor locked up, you probably have a bad rod or main bearing.
When I rebuilt the motor, it was my first so please forgive my not remembering. Can I pull the oil pan to check for the bad rod or main bearing, or does the head and all have to come off?
Thanks for your reply.
Jimmy
   / Yanmar 2310 down what is it worth? #4
Should be able to drop the pan and check. You can loosen the rod and main caps one-by-one and try turning the engine by hand after each time you loosen one until you find the culprit. Went through this process w/ my Mitsubishi not too long ago.....had a rod bearing spin and she locked up tighter than a drum! Very simply fix really though. What's time and money compared to the satisfaction of completing a job well done?!?! ;)
Good luck... A set of bearings, some gaskets and turning the crank is probably just be a few hundred $$ and a weekend of your time. A tractor with a seized engine is worth maybe half of a running one and yours looks like a clean unit worth getting a fair price out of..
   / Yanmar 2310 down what is it worth? #5
Yea just pull pan. U can look at bearings that way. I would say the tractor worth 750 as is.
2018 Volkswagen Jetta Sedan (A50324)
2018 Volkswagen...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
2013 Ford E-350 Enclosed Service Van (A50323)
2013 Ford E-350...
2018 Komatsu WA500-8 Articulated Wheel Loader (A50322)
2018 Komatsu...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52128)
80in HD Tooth...
