Another good source for replacement rims is Sparex USA or Sparex Canada. Many times our YM machines are the same as the Deere 50 Series and 70 Series tractors. Some of the older Mitsubishi rims fit too.Looking for non rusted rear wheel rims for Yanmar 220D
Thanks!Suggest measuring wheel diameter and width, bolt pattern, and hub diameter, and calling Hoye or Alexander. If no luck there, call Hey Wheel
Thank you!Another good source for replacement rims is Sparex USA or Sparex Canada. Many times our YM machines are the same as the Deere 50 Series and 70 Series tractors. Some of the older Mitsubishi rims fit too.
The difficultly you will find is matching the 4WD rims. They have to match perfectly for tire size mounting to ensure the LEAD and LAG are without specification, else you will damage the internal gears of the 4WD and that is really costly !
