Yanmar 2000D Rear lift problem
   / Yanmar 2000D Rear lift problem #1
Tim_Ternest
Ok thanks for reading first off,
On my 2000 the rear lift has been acting up.
i was using my harrows and the lift just quit lifting but i was hearing a fluid or pressue sound from under my seat. I drop the harrows and got another tractor aand finished my job. Rehook the harrows and seem to lift ok still hearing hising sound from under the seat. It quit again, i pulled out what looks to be a check valve from under the seat located above the rear lift adj know between your legs. BIG NUT with spring . This valve is sticking and a small seal was broke
can i replace this check vale or re build it? And at what cost? and part number and soruce? or anyone got a replacement or used on thanks Tim
FORD 1900 TRACTOR (A51247)
FORD 1900 TRACTOR...
UNUSED Grey Metal Roof Panels (A53117)
UNUSED Grey Metal...
2015 FORD E350 16FT BOX TRUCK (A54607)
2015 FORD E350...
Kalamazoo 8-6-W Metal Cutting Band Saw (A51695)
Kalamazoo 8-6-W...
2007 Case 580M Series 2 Loader Backhoe (A53117)
2007 Case 580M...
Honda UTV (A53117)
Honda UTV (A53117)
