DWeinreich
- Joined
- Feb 5, 2011
- Messages
- 25
- Tractor
- Yanmar 187D
I've got a problem and maybe one of you has the answer. I was pushing some snow around the yard with the front end loader with 4wd engaged. Something happened and now 4wd doesn't work when I go forward. There is a noise coming from the front axle assembly, possibly from where the drive shaft connects to the axle. The sound is like a gear that isn't engaging fully. The sound happens going forward, but not backward. I'm thinking something may have sheared off. The drive shaft still spins so the problem is somewhere forward of that.
If you have any clues or suggestions what to do to determine the cause and how to fix it I would appreciate hearing from you
