Yanmar 186d your thoughts
   / Yanmar 186d your thoughts #1
houstonscott
Elite Member
Oglesby, Texas
Kubota L3800, Kubota GR2120, Kubota RTV1100, Kubota 5100sc
Found a Yanmar 186d with 136hrs on it. What's a fair price? Looks like a time machine. Any issues with this model?
HS
   / Yanmar 186d your thoughts #2
1986 was the last year it was sold. That averages out to 5 hours a year. :rolleyes: If that is correct it ought to be worth the maximum. It is really worth what you are willing to give. Have you still got your 1610?
   / Yanmar 186d your thoughts #3
That's a 3 digit hourmeter. My YM186D only shows 36 hours! :D But when I bought it I had to rebuild the worn out steering box - and discovered it had been rebuilt before. So probably over 2000 hours actual.
If you have really found an as-new YM186D it is worth whatever you have to pay for it. I think this is the best small tractor ever.
But verify the apparent condition. Ask for the original purchase paperwork and manuals, if possible. While a no-hours 30 year old tractor is possible, a misrepresentation is also possible.
Answering your questions - No issues with this model. With real high hours the normal stuff wears out same as a car - battery, belts, maybe eventually the starter, etc. This is a generally bulletproof model.
Price? maybe over $5k for the bare tractor (if its really that good), plus the value of any implements. There was a recent thread discussing the same issue, maybe the same tractor. I think that guy concluded it was really 1030 hours and well maintained.
   / Yanmar 186d your thoughts #4
I totally agree with California. my old YM169D read 800 something hours when I got it, after 1 year I finally fixed the tachometer cable and it started to record hours again, however in that time frame I kept track of every hour I used it. Before I sold it I rolled over the hour meter back to 0. I estimate my Yanmar had anywhere from 2000-4000 hours on it, however it ran awesome, only had minor repairs.
   / Yanmar 186d your thoughts #5
I have a 186D....great little tractor. Hours could be anything....836...936...who knows. I will bet it is not 136.
With that said......if it checks out.....$4500 to $5500 would be an OK price. FEL will add another $1K. Those little diesels go a long time.......good luck!!:thumbsup:
   / Yanmar 186d your thoughts #6
Here's the thread where the guy bought a claimed 14-hour YM186D. After posters asked him questions, it appeared to be low hours but not 14.
http://www.tractorbynet.com/forums/yanmar/244094-our-new-186d.html
Here's his photo in post #103. Note the paint is worn down to bare metal on the fender grab-handles.
Way off-topic comment on that photo: I cut 2 inches off the range shift lever of my YM186D so I could swing my leg across without snagging on that shift lever. To shift ranges means leaning forward a little more, but its still closer than the 4x4 lever - not difficult at all. In my opinion they should have built it with that lever shorter.
   / Yanmar 186d your thoughts #7
I cut off my 2002d gear shift lever and range shift lever for the same reason.
7' ROTARY MOWER (A51243)
7' ROTARY MOWER...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A51243)
2014 MACK ELITE...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2008 Nautica International RIB 24ft Cat Boat (A50324)
2008 Nautica...
Bucket (A50322)
Bucket (A50322)
