yanmar 1700 tractor
   / yanmar 1700 tractor #1
gino54
michie,tn
yanmar, 1700
Hi,
my name is gino in michie tn. when i engage the pto, (there are 3 on this model) and i use pto 2, it is sometimes difficult to dis-engage it when using it. what are some of the remedies to make it more easier. all my fluid levels are full.
   / yanmar 1700 tractor #2
if it has not been used, the detents are probably pretty stiff.
also, try not to have any tension on when shifting.. IE.. not bound up, use clutch..e tc..
   / yanmar 1700 tractor #3
Does this tractor have a two stage clutch out of adjustment maybe?
Jim
being relatively new in handling tractors, i'm not sure what you are saying about the clutch. after mowing, and getting ready to take a break, it is just difficult to dis-engage. i am currently using the "armstrong" method by going down to pto 1 and then TRYING to get it back into neutral to stop the pto from turning. thanks to responding...(almost forgot to say, yes I do have the clutch engaged) gino
being relatively new in handling tractors, i'm not sure what you are saying about the clutch. after mowing, and getting ready to take a break, it is just difficult to dis-engage. i am currently using the "armstrong" method by going down to pto 1 and then TRYING to get it back into neutral to stop the pto from turning. thanks to responding...(almost forgot to say, yes I do have the clutch dis-engaged. gino check this response. (clutch is dis-engaged)sorry for the mistake.
   / yanmar 1700 tractor #6
thanks to all who responded to my pto query. I was in decater, al. where the yanmars are re-furbished, and one of the parts dept employees gave me this info. come to a complete stop and put the tranny in neutral. rock the tractor in and out of either 1st gear or reverse while putting the pto lever in neutral. do this once or twice and things should sync and the lever will go in the neutral position dis-engaging the pto. i tried this when i got home and voila!!! it worked like he said it would.
gino
John Deere L125H Skidloader (RUNS) (A50774)
John Deere L125H...
1987 International S1900 Flat Bed Truck (RUNS)(TITLE) (A50774)
1987 International...
2019 ExMark S-Series 72in Zero Turn Mower (A51692)
2019 ExMark...
377811 (A48836)
377811 (A48836)
McDon 75s 40' Flex Draper Head (A52349)
McDon 75s 40' Flex...
