Yanmar 1700 random skip
   / Yanmar 1700 random skip #1
buntrock
st matthews s c
yanmar 1700
Just installed new rings rod brngs head gasket,head checked out OK ,did not tamper with injector mechanicals.Installed water pump,"Hoye Tractor," temp and oil pressure gauge.Radiator new.30-40psi oil pressure @190 temp.No unusual smoke runs great except the annoying skip. Doesn't have regular pattern just happens sometime under load or just idleing.Have checked fuel lines for cracks.Any ideas?
   / Yanmar 1700 random skip #2
Still sounds like air getting in the fuel sytem. I would check the fuel lines from the tank to the injectors. I had this problem on my Ford tractor once and it took some time to find the problem. It was one conector at the injector, the rubber seal went bad and air was getting into the system. The heat from the motor would dry the fuel, so it took a very cold day in January to find where fuel was leaking out. It was not much, but gave me the same problem that you are having.
Don't know what happened,but skip went away ! Ran tractor yesterday couple Hrs. here in SC around 95-98 degrees no problem.Must have Gremlin messing with me.
   / Yanmar 1700 random skip #4
I know that with mine if I do not take the time to bleed out all the air from the pump that it will miss a bit for the longest time until it finally works out that last little bit of air. That is probably what happened to you. there was a bit of air left in the pump and when it finally got worked out--presto full power.
Happy tractoring!
Mike
Bucket (A50322)
Bucket (A50322)
2018 WOOD MAXX TM 86H WOOD CHIPPER (A51243)
2018 WOOD MAXX TM...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2018 Toyota RAV4 Hybrid XLE AWD SUV (A50324)
2018 Toyota RAV4...
Brent 644 S/N B29820157 (A52128)
Brent 644 S/N...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
