yanmar 155d stuck in 4 wh. drive
   / yanmar 155d stuck in 4 wh. drive #1
pinantanman
pinantan lake b.c.
YM 155d
my yanmar was in 4wd drive when I got it and the push lever is down and wont come up ?????
   / yanmar 155d stuck in 4 wh. drive #2
Probably get a better answer in the Yanmar section.
   / yanmar 155d stuck in 4 wh. drive #3
Slight diferances in wheel size and gear ratio can cause driveline binding.
drive foward and back in a strait line while pushing on the lever.
If you have a loader that can push down and lift the front wheels off the ground that should do it too.
JOHN DEERE/UNVERFERTH 1700/330 (A53084)
JOHN...
2016 Mercedes-Benz GL450 4MATIC AWD SUV (A50324)
2016 Mercedes-Benz...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A50323)
2017 Mack GU713...
2015 Freightliner M2 106 Terex BT2047 10-Ton Crane Truck (A50323)
2015 Freightliner...
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
2015 INTERNATIONAL PROSTAR TANDEM AXLE MID ROOF SLEEPER (A52577)
2015 INTERNATIONAL...
