Yanmar 155 D help ...please
   / Yanmar 155 D help ...please #1
snowman6363
yanmar 155d
I am a new owner of a 155d, since i bought it, when starting it makes a banging sound (sort of like a rod knock) however when i pull the decompress lever there is no sound, that being said the tractor would start fine and run fine other than black smoke when accelerating.... i was using it one day when all of a sudden it lost power, i changed the filters but with no luck, any suggestions or does any one know of a repair shop near clevealnd ohio where i can take this to.. i called several folks who all said that they could not fix it due to unavailibility of parts
thanks in advance
ok i did a little bit more investigation... I removed the injectors and found that the rear injector was not spraying fuel, i disconnected the injector and both line had fuel flowing, i even swapped the injector and still no flow to # 2 cyl.. how hard is it the rebud one and does any one have any advice
2011 Dodge Nitro SUV (A51694)
2011 Dodge Nitro...
UNUSED HURRICANE D6028 - 5' JOB BOX (A51248)
UNUSED HURRICANE...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
AFF 8888 CANTILEVER WASTE OIL DRAIN (A51248)
AFF 8888...
2008 Felling Step Deck Low Boy, 42', 82,500 GVWR (A52384)
2008 Felling Step...
APPROX. (7) NEW 16' SPAN 4/12 TRUSSES (A51248)
APPROX. (7) NEW...
