yanmar 1500 coolant
   / yanmar 1500 coolant #1
Coyote
North Carolina
Yanmar 2000B & Skat Trak 1300D skid steer
Anyone know the capacity of the cooling system on a 1500 so I can get the 30% AF right? Thanks
   / yanmar 1500 coolant #2
Coyote, I'm not sure about the capacity, but I normally pre-mix my anti-freeze/coolant at 30-40% and then add it to the radiator.
I don't know about the 1500, but if it doesn't have a water pump, it's best to be sure the mix is right when it's added.
Tony
   / yanmar 1500 coolant #3
Coyote,
I have a 1500 also and can't tell you the capacity, but I just mixed up a bunch at the 30% to 40% and filled it up. It's never given me any trouble at all.
And Tony is right. The 1500 does not have a water pump so the correct mix ratio of the coolent is very important. With that ratio right, you should be good to go. One other thing, when I got mine it did not have and overflow bottle. I bought one and it works very well. Make sure you have one.
Mike
   / yanmar 1500 coolant #4
If you don't already have it, install a temp guage. My understanding from some of the senior members is that the 1500 should have little or no coolant. Straight water if possible. Apparently, the anti-freeze disrupts the "natural" convection flow system.
I run straight water with "water wetter" and have maxed out at 235 degrees on a hot, 90 degree day while bush hogging. If freezing is not an issue, I think that's your best bet.
   / yanmar 1500 coolant #5
As I understand it, without a pump, the 1500 uses natural convection (induced by heat) in the coolant to circulate. If you use more than 30-40% antifreeze, the mixture is too thick and instead of the usual raise in boiling point one would expect with antifreeze, you get a lack of convection/circulation and failure to cool the engine.
So a thinner mixture is preferable for better convection. Some have suggested water with a wetting agent--of course then the fluid boils at 212 degrees (or slightly higher if adjusted for pressure).
I imagine anything less than 30% antifreeze will work, just don't let the engine freeze in the winter.
McKee 504 3pt. Snowblower (A50774)
McKee 504 3pt...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50323)
BW RVB3405...
2002 Bobcat 753 Skidloader (NOT RUNNING) (A50774)
2002 Bobcat 753...
JLG 1255 Telehandler (A52748)
JLG 1255...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
1990 Ford Ranger Pickup Truck, VIN # 1FTCR11TXLUC19238 (A51572)
1990 Ford Ranger...
