Yanmar 1401 3 pt lift
   / Yanmar 1401 3 pt lift #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
I am looking for a 4 ft wide cultipacker. I have found models that weigh from 308 pounds up to 800 pounds. I am wondering how much weight the 1401 can lift with the three-point lift. Any help will be appreciated.
   / Yanmar 1401 3 pt lift #2
Forget 800 lbs. My little YM186D (similar size) wouldn't lift my 750 lb backhoe, not even close.
308 lbs should be fine but wait for others to answer who have done this.
   / Yanmar 1401 3 pt lift #3
The parts manual for the 155 states 926# maximum lift.
The repair manual for the 155 states "more than 1210#".
The repair manual for the 169 states 1102#.
These are all "at the pins".
All the above may not jive but straight out of the manuals for what it is worth. I agree with California 800# is way to much.
   / Yanmar 1401 3 pt lift #4
The distance the weight is located from the arms is almost as important as the actual weight. The farther you get from the tractor the less weight you can lift. You might be able to lift 900# at the pins but might be only able to lift 200# if the weight is 8' back (just a made up number). Cultipackers are typically pretty shallow implements so, if you can get it right up close to the tires, you would have a better chance of it lifting it.
   / Yanmar 1401 3 pt lift #5
I would get the lightest available. You can always add weight if needed. With your 2wd you are probably going to need suitcase weights on the front to pull/lift any ground-engaging implement. I had to put 200# weights on the front of my YM2000 to keep the front wheels on the ground when pulling/lifting my 5' box blade.
STOP!!!! PLEASE READ ALL TERMS BEFORE BIDDING!!! UPDATED TERMS!! (A50775)
STOP!!!! PLEASE...
2021 KUBOTA SVL75-2 SKID STEER (A51246)
2021 KUBOTA...
2018 JOHN DEERE 50G EXCAVATOR (A51246)
2018 JOHN DEERE...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
5 Piece Combo Kit 20V Lithium-Ion Drill/Fan/Batteries (A51573)
5 Piece Combo Kit...
