Yanmar 1300D Engine - Replace or Rebuild Parts?
   / Yanmar 1300D Engine - Replace or Rebuild Parts? #1
rtimgray
Veteran Member
Hey there. I've had a YM 1300D for several years and now it looks like I've finally got a major problem. I haven't used it in the last couple of years (been using our F16D instead), and it has mostly just sat around. My brother came and got it and used it for a little tilling. Thought it was hot, so opened the radiator and it was empty and the oil pan was full (of water/oil mix). I passed him a service manual that I had for it and he tore into it and said the head gasket was fine, and guessed it was either a crack in the head or a crack in the block. Sooooo...
anyone have any leads on a repair parts or (preferable) a good motor in running condition for a 1300D? If you have or know of one available, PM me and let me know. The other option is, if the engine isn't available or costs too much, is anybody interested in a YM1300D parts tractor, complete with bad motor (PM me on that as well). Thanks.
   / Yanmar 1300D Engine - Replace or Rebuild Parts? #2
Sounds like you may have a cracked head on your 1300. I had a cracked head on my ym2200 and there was water in the oil. I had taken the head off an had it rebuilt. I was really surprised on what they can do with cracked engines and heads. I have had it for about two weeks now and it so far so good. I would take the head off and look for any cracks then go from there. If you find a crack look into a automotive engine rebuilder to repair it. Good Luck
   / Yanmar 1300D Engine - Replace or Rebuild Parts? #3
Go back and recheck the headgasket. My 2310 had a cylinder lead into the coolant. I discovered this by opening the radiator and turning over the starter. alot of bubbles in the radiator. I took the motor apart and I had the head checked and milled and the machinist said the head was fime. After I put the engine together and got the tractor running, I inspected the headgasket and noticed the leak area. It didn't look anything like the blown headgaskets I had seen in gas engines before.
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 Ford Explorer AWD SUV (A50324)
2018 Ford Explorer...
2001 Ford F250 Pickup (RUNS) (TITLE) (A50774)
2001 Ford F250...
Polecat Swift 206R 20ft Towable Boom Lift (A50322)
Polecat Swift 206R...
