yamnar 2000
   / yamnar 2000 #1
bruce60
Frisco
yanmar2000
Tractor ran great for an hour then bogged down and died. Will crank again and idle for a few minutes and die again. Thanks..
   / yamnar 2000 #2
Was you keeping your foot on the Throttle/Gas pedal so it don't fall? I you were then my guess you've got water in the fuel. Drain the Tank and remove the Fuel Bowl and clean it. Here's the Part #3262 for a new Filter at NAPA. Hoye's site will tell you how to bleed it. There not much to it. Just takes a few Minutes.
   / yamnar 2000
OK thanks.
   / yamnar 2000 #4
Did this correct the problem?
   / yamnar 2000
I think its a blown head gasket!
   / yamnar 2000 #7
Now's the time to get it taken care of. Which I do have trouble keeping up with which thread.Ha.... No mention I recall of water in the oil so IMO. if you think it is the HG. it's time to pull it down. Not much to it and most any Auto store could tell you were to have it checked . My local Napa. has a Mach. shop. May try them to have the head checked. Don't make the big mistake and finding out the hard way by running it Hot. I noticed today it won't be long here in Ga. and i'll be sharpening blades.
UNUSED CFG INDUSTRIAL MH12RX EXCAVATOR (A51247)
UNUSED CFG...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53472)
NEW Work Saver...
2020 KUBOTA RTV...
2001 CATERPILLAR 140H VHP MOTORGRADER (A51406)
2001 CATERPILLAR...
Deere 9970 Cotton Picker (A53472)
Deere 9970 Cotton...
