XUV options
   / XUV options #1
cef2lion
Central PA
JD 4410, JD455
Installed a few options this weekend on the 850 XUV. Put on the Deere winch kit, deluxe soft door kit, and deluxe light kit.
The Deere winch kit is the new Warn RT30. Went pretty well. Needed to remove the cup tray and lift the plastic cover over the shift knobs to route wires going to the battery. I had to remove the knobs off the shifter, rear diff lock and emergency brake to get that cover off. The winch solenoid mounts under dash next to glove box. Took extra care to zip tie the wires under the shifter area going into the battery area so they don't rub. The battery wires from the solenoid to the battery are just long enough so you need to route carefully. They show the remote control plug being mounted in the lower part of the glove box. I didn't mount the plug as yet as I wanted to think on that. I usually keep a number of things in my glove box so I wan't sure I wanted to mount it there. Maybe even right on the dash. To mount the winch you need the front receiver option. It is 2 inch on the XUV. Mounting the receiver looked simple enough except it wasn't easy to get your hand behind the bumper to put the nut and lock washer on. Small hands help. There appears to be an extra connection point in the wiring harness near the solenoid. On a ATV I think there is also a handle bar mounted switch that would attach to those wires. Might look into a dash mount switch since there are open switch slots in the XUV dash. That way you could control the winch while sitting in the XUV without using the remote. There is also an extra wiring kit that allows you to run an extra set of wires to the rear in case you want to mount winch in back receiver of XUV.
The soft door kit was pretty straight forward. There are filler panels that need to be install on both sides. The one on the passenger side required me to remove the air filter restrictor indicator. I also had to loosen the air filter box to be able to position the filler panel. I found out you need to work carefully around the battery area with nuts and bolts. Drop something in there and you need to pull the battery as my luck had everything findings its way under the battery tray. The filler panel on the drivers side gave me some fits. Just didn't seem to want to fit just right. I got it on but want to take another look at it. Very tight where it attaches to the back of the deluxe cab. I think I need to loosen the cab mounts in the rear and side the cab towards the drivers side just a bit. You need to put Velcro on the cab for the back window. In front of each door there is a small opening that gets a vinyl window. I have not put the velcro on as yet. Waiting for warmer days so it sticks well. Doors just lift off. Kit is pricy.
On the deluxe light kit. My turn signals work even with the key off. Is that normal? The instructions seem to say you need the key on to test them. I double checked how I plugged in the harness. I think I have that right. The hazards work without the key which I expected. Mounting the brake light switch by yourself is a real pain. Hard to get all the hardware in place hold it and get the nuts on all with very limited space. Longest part of the install. New headlight switch now has two positions. First one just turns on the tail lights. I was hoping the front turn signals would also have a parking light feature. On with the tail lights and head lights but not so.
Still have the Curtis heater on order.
   / XUV options #2
I agree with you that the brake light was difficult to do by yourself. Initially I didn't see the rubber boot that covers the brake sensor...so I got to install the hardware twice! What a pain. My turn signals work with the key off as well. I thought that could have been improved, but all in all, the light kit is a nice option to have.
I will say that installing the bed lift kit was a cinch. It literally took 10 minutes.
Installing the Rear Screen for the standard ROPS is a pain to do by yourself as well. It is a big balancing act getting the first bolt in place. After that it doesn't take anytime to set in place.
   / XUV options #3
I would imagine the turn signal and what not would work without the key since they do on my tractor.
   / XUV options #4
I had the dealer install the deluxe light kit on my XUV just last week. I went out and checked it and sure enough the turn signals and flashers work without the key. The key has to be on the headlights or parking lights. I traded in a HPX and I am pretty sure the key had to be for the turn signals (but I am not too sure of anything these days).
   / XUV options #5
i would stick with useing just the remote on the winch because it's real easy to stack the cable on a winch . if you are in front or next to the winch you can see the cable and stop it from stacking and it won't get pinched if not you'll ruin a cable and drum really quik. i would keep a pair of welding gloves they are thick and they will stop most cable burs (you shouldn't have any) from penetrating and guide the cable with your hand while spooling in with the winch.
   / XUV options #6
The turn signals we have on our 6X4 Gators over here stay on without the key being on. Like Darkday said, the turn signals on my tractor require the key to be in the ON position.
Is the front receiver mount the only front mounting option for the XUV? Is there a way to permanently mount the winch?
   / XUV options #7
there are some holes on the bumper right obove round tubing on the flat part going up you could mount a winch there.
UNUSED CFG INDUSTRIAL QH12R EXCAVATOR (A52706)
UNUSED CFG...
Case 1083 20ft Corn Head (A53473)
Case 1083 20ft...
2015 Freightliner Bucket Truck (A52748)
2015 Freightliner...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2012 DOOSAN G25KW GENERATOR (A53843)
2012 DOOSAN G25KW...
