XU6168 INTEMITTEN STOPS PULLING THEN WILL START PULLING AGAIN
   / XU6168 INTEMITTEN STOPS PULLING THEN WILL START PULLING AGAIN #1
TROTTER FARM
LSXU6168
HEY GUYS, I NEW HERE I HAVE HAD SEVERAL OLD FORD TRACTORS. I JUST BOUGHT A NEW TO ME LS. WHILE RUNNING TRACTOR OCCASIONALLY IT WILL STOP PULLING THEN START PULLING AGAIN. IT IS THE POWERSHUTTLE MODEL. CAB TRACTOR IS THAT MATTERS. ANY HELP OR EXPERIENCE WITH THIS PROBLEM? THANKS IN ADVANCE
   / XU6168 INTEMITTEN STOPS PULLING THEN WILL START PULLING AGAIN #2
A bit more information would be helpful. By pulling, do you mean driving forward? Are you pulling implements when it stops only?
What does the engine do? Does it lug down or stay at the same RPM?
Does it jerk and pop? or is it smooth?
Does it grind?
I'm thinking maybe a clutch issue.
   / XU6168 INTEMITTEN STOPS PULLING THEN WILL START PULLING AGAIN #3
The power shuttle uses an electronically controlled wet clutch. There is a clutch pedal, but it only operates a switch in the dash.
If the wet clutch loses hydraulic pressure, then I guess it could slip.
How many hours on tractor and when it acts up, is your foot touching the clutch pedal? These tractors do have a function that saves the wet clutch from people that tend to ride the clutch. If you ride the clutch, the tractor will automatically engage the clutch to save the clutch from abuse.
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
2017 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2017 GENIE GTH-636...
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52128)
2016 Kawasaki 70...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A52128)
2019 Ford F550 4x4...
2003 International 4300 Flatbed Truck w/ Liftgate - Inoperable - 7.6L DT466 Diesel Engine (A52128)
2003 International...
