XR4140HC knocking, squeling, screeching metal on metal sound
   / XR4140HC knocking, squeling, screeching metal on metal sound #1
chenderson
Gray, Maine
LS XR4140HC
Guys, I need help. XR4145hc with 182 hours. Got in the tractor the other day and started her up. Ran fine for 3-4 seconds then runs really rough with a crazy amount of noise. The knocking is so load I'm afraid to stand next to it and get a rod in the face. Sounds like metal on metal with no lubrication. First thought was starving for fuel. I've pulled the line from the tank at the filter and used compressed air at the fill to push fuel through with no problem. Primed it 2 or 3 times thinking air in the lines. I can throttle it up but I'm afraid to damage something. It is 4.5 years old so hoping its under warranty but dealer is on vacation for a couple more days. Any help would be appreciated.
   / XR4140HC knocking, squeling, screeching metal on metal sound #2
Did you check the oil level? Coolant level?
Yep, all fluids are fine. not leaking anything either. No flashing lights, errors, etc.
Tandem Axle Rear Truck Frame (A51692)
Tandem Axle Rear...
New Holland LX885 Skidsteer (A51573)
New Holland LX885...
UNUSED FUTURE GD47 47" LAND LEVELER (A51248)
UNUSED FUTURE GD47...
RoGator RG1300C Air Max Precision 2 Spreader (A53342)
RoGator RG1300C...
1992 Effer 7600 2S Knuckleboom (A51691)
1992 Effer 7600 2S...
(APPROX 18) 2" X 6" X 68" THICK TUBING (A51247)
(APPROX 18) 2" X...
