XR4140 PTO Shaft extender?
   / XR4140 PTO Shaft extender? #1
XR4140
Bronze Member
MO
18 LS XR4140
Finally got around to hooking up a quick hitch. With the brush hog, the drive shaft is now just a little to short to connect.
Can anyone tell me what size pto extender I need? (not the length)
Thanks!
   / XR4140 PTO Shaft extender? #2
If you want to know the size of the shaft, it should be 1 3/8 by 6 tooth, standard sizing for a PTO shaft. That information is in your owners manual.
George
Thanks I appreciate it!
   / XR4140 PTO Shaft extender? #4
Do you have anything else with a pto shaft? I have never heard of a pto shaft extender. I would check the local farm eq sales paper or craigs list for another shaft.
   / XR4140 PTO Shaft extender? #5
in the FAQ's it speaks this issue.
"Will The Top Link or PTO Shaft Need to Be Replaced?
Since Pat's Easy Change system will result in implements being attached 3-4" further away from the tractor than with a standard 3-point hitch, if your 3-point hitch top link or your implement's PTO shaft only has a few inches of extra length, you may need to replace those items with longer ones. Manually adjustable 3-point hitch top links can be obtained inexpensively from a variety of sources, both online and offline".
I have never seen a PTO side "Extender" , But I have seen implement shaft replacements all over the place.
   / XR4140 PTO Shaft extender? #7
tHEY SELL THEM AT EVERY FARM AND HOME STORE I HAVE BEEN IN . RK , ORSHELYN. COUSIN CHARLIES . FARM AND HOME , TRACTOR SUPPLY.
   / XR4140 PTO Shaft extender? #8
I would simply replace the pto shaft itself. That is one reason I have not gone with a quick hitch, I would probably need to replace the pto shafts on all my implements as well.
Taking a look at the extender, seems sturdy enough, but again, I see it as a point of failure. For me, I wouldn't go with this option. It maybe cheaper than replacing the entire shaft, but not worth the risk. I wouldn't do it.
Orsh only had the pin on type. I had to order the quick disconnect kind (less than $40)
I dont like to have to buy another piece...but being able to switch between my blades and brush hog that fast and easy is worth it.
   / XR4140 PTO Shaft extender? #10
You could also buy a length of PTO shaft tubing with the same profile you have and replace just the tube with the right length. This would be my choice.
PTO shaft extenders will create a lot of stress on the PTO bearings.
Vermeer 840 Discbine (A50774)
Vermeer 840...
2016 Nissan NV200 Cargo Van (A50323)
2016 Nissan NV200...
Ashland 5 yrd Dirt Scraper (A50515)
Ashland 5 yrd Dirt...
2018 Gatormade 20+5 Gooseneck Trailer (A52748)
2018 Gatormade...
2016 Ford Taurus AWD Sedan (A50324)
2016 Ford Taurus...
2013 Peterbilt Heil Side Loader Garbage Truck (A50323)
2013 Peterbilt...
