Xr4046h with 1000 hours
   / Xr4046h with 1000 hours #1
dan8152
Burlington wi
Kubota L2501 hst, belarus 825
Is that too high hours? Looking at a used one and wondering what to offer. Looks well used and not abused.
   / Xr4046h with 1000 hours #2
Have you look at some Tractor Mike videos?
He does a decent job of helping folks with pointers on what to look for.
Hours alone not necessarily an indicator of tractor condition.
But hey hang on out here and add a few more details on this particular tractor.
Like year, configuration, ie. FEL or not etc. and you'll get lots of help.
Yep, sorry sometimes I'm no help at all!:D
   / Xr4046h with 1000 hours #3
If it has had scheduled maintenance on time, the loader was greased regularly, and everything works, I wouldn’t be scared of it.
   / Xr4046h with 1000 hours #4
I agree with 3Lfarms - with proper maintenance (including greasing) I wouldn't be scared of it. You could always do a compression and blow by check pretty easily. A lot of the other items should have visual or audible indicators of things that aren't quite up to par (if any). That said, it's always nice to know what it was used for too - a tractor pulling a finish mower is taking a lot less abuse than one used to dig out stumps and move them around with the rear wheels off the ground...
Tractors seem to hold their value pretty well. I'd start by pricing out a similar new machine at a local dealer and put some numbers together around things like:
1. Is it still under warranty? If yes, you've got some time to work with the tractor without potentially shelling out any large amount of money assuming the warranty transfers. If no, I'd set aside a couple thousand dollars as a safety net.
2. Maintenance. Hopefully it's all up to date. If not I'd check out the manuals online to find our what 1,000 service looks like. Assuming fluids, filters, etc. at a dealer that's probably $500-1,000.
3. Consider what some of the new options are worth to you - remote raise/lower 3 point linkage, 3rd rear remote, etc. that you would find on the new XR41XX series tractors.
Does the current owner have a price they're looking to get?
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
2020 Hino 195 Cab and Chassis Truck (A48081)
2020 Hino 195 Cab...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2016 Chevrolet Impala Limited Sedan (A48082)
2016 Chevrolet...
2016 Ford Transit 250 Cargo Van (A48081)
2016 Ford Transit...
