XR3037C Steering issue.........
   / XR3037C Steering issue......... #1
mjstef
LS XR3037C
I have had my tractor for 5 days now. While mowing i am noticing the steering has a mind of it's own. When i turn to full lock right or left it will hold but if i turn part way and look over my shoulder at the mower, i turn back around and notice the tires are starting to head toward straight again WITHOUT MOVING THE STEERING WHEEL! Anyone having a similar issue? Dealer is stumped and has a call into LS. 12 hours on the clock......
   / XR3037C Steering issue......... #2
Re: XR3037C Seering issue.........
I would think that if you turn the wheel and let go that continued forward movement would tend to make the tires want to turn straight again. I guess what you are seeing is the result of hydraulic steering with the wheels wanting to straighten themselves back up without the wheel moving. Hydraulic steering is not like having a steering box with gears in it that hold the tires where the steering wheel is. It sounds as if your hyd. steering cylinder or pump has an internal leak allowing fluid to get by the internal seals. Let us know if LS will have a correction to this problem. I haven't noticed this with mine yet but only have 32 hours on the clock.
Yes, I don't let go of the wheel but it starts to straighten out. I tried on a ten acre field and it never would straighten out all the way but would go quite a bit. My old New Holland has the same steering system and it would hold wherever you put the wheel. I too think there must be a leak somewhere. Looks like i'll pass you up in hours in a week or so LOL!
   / XR3037C Steering issue......... #4
Without turning around and looking behind you does the same thing happen? If it were something wrong with your tractor it seems you would notice it any time you turned without hitting the stops. Maybe you are letting up a little on the pressure when you turn around and what you are noticing are the R4 tires trying to self correct. Let us know!
It happens no matter what. It's just when i turn around i don't have the tendency to keep correcting it as the visual is not there...........
   / XR3037C Steering issue......... #6
Most of my hours so far have been just moving it around for installing accessories like lights and back up camera system etc., Lifting heavy items like box blade, flail, post hole digger for rebuilding / refurbishing them. My main use will be in winter. After I retire I'll get much more summer use with the attachments.
I saw you put on different lights. I tried the factory lights at around 11:30 the other night and they seem excellent. Not sure i need any more lighting. Where you finding an issue with yours?
   / XR3037C Steering issue......... #8
No issue with mine but mine did not come with any rear lighting. I added the combination LED flood/spot light on the back. Also added the flashing amber strobes (3 front & 3 back), Reflective tape on both sides. I want to be seen when on the road. The more lighting I have the better my chance of being seen. Adding my own was cheaper than ordering factory lighting. Also installed my own radio at less than half factory price.
Front lighting (hood and cab mounted) work fine. Hood mounted lights are blocked by the bucket so I don't use them that often. I made a bracket and mounted it to the mirror brackets to relocate the cab lights so I don't have to disconnect them when I want to pop the top for service or any electrical work I may want to do.
   / XR3037C Steering issue......... #9
Mine does that return to center thing too. I have to continue to turn the wheel to keep the same radius turn when I'm not on the stops.
Good to know i'm not crazy. Guess we'll see what they say............
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A50323)
2021 Chevrolet...
Kinze 3600 16 R Planter (A50514)
Kinze 3600 16 R...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
SpotWeld RockerRite 480V Arm Type Spot Welder (A50322)
SpotWeld...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
John Deere 946 Center Pivot Rotary Mower-Conditioner (A52128)
John Deere 946...
