XR3037 no temp reading and will not regen
   / XR3037 no temp reading and will not regen #1
fordtrucknut
LS xr3037
My temp gauge stopped working about a week ago.
and now the tractor has kicked into limp mode because it will not regen.
The temp sensor omh'd out in spec, but I swapped it with the air intake temp sensor just to try it. Still nothing, I've checked all harness wires and connectors.
Is it possible the thermostat failed and this little engine just can't get hot without it? I hit all over the engine with an IR thermometer and its not hot anywhere, and you can run it for over an hour and pop the radiator cap and won't spill a drop.
   / XR3037 no temp reading and will not regen #2
Sure sounds like the thermostat stuck open. I would imagine regen won't work without operating temperatures.
   / XR3037 no temp reading and will not regen #3
FTN, try removing the neg. battery terminal for a minute. Then, reinstalling it after cleaning what may be poor connectivity.
Mine is almost 10 yrs old now with about 1K hrs on the clock.
It does some of the things you describe from time to time.
I just reboot the system and/or make sure all is well for good grounding to take place.
It's a good thing it only happens every year or two or I'd have it checked out by a shop.
Hope it works for you.
   / XR3037 no temp reading and will not regen #4
Yeah, sounds like your thermostat is stuck open. The computer wont allow a regen unless its at operating temps. If your never at operating temps, then it wont regen. Replace that thermostat and see what happens.
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
Takeuchi Skid Steer (A49461)
Takeuchi Skid...
TAKEUCHI TB235-2 EXCAVATOR (A51242)
TAKEUCHI TB235-2...
300-gal Poly Sprayer 60ft Boom (A52128)
300-gal Poly...
White 2-55 Loader Tractor (A50514)
White 2-55 Loader...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
