Oil & Fuel XJ2025H Right Front Axle Leak
   / XJ2025H Right Front Axle Leak #1
BrunoGA
Jasper, GA
LS XR3037H
Good evening all. I know there is a post about "4WD front axle leak", but I think perhaps my issue may be different, we'll see. My XJ only has 6 hours on it, and I noticed when I pulled it out from the shed last week the front right axle looked wet, and there was the start of a puddle underneath the tire. I wiped it all down to see if I could spot anything suspicious, but didn't see anything other than hand-tightening down the blue cap on top of the axle. A few days later I got ready to use the XJ again but before I did checked the axle and fluid level. No other leaks or wetness, but I did top off the fluid from the left side red cap (with dipstick).
When I returned to the shed a couple hours later I checked it again and there were two wet "runs" from the blue cap down the axle. So it "appears" to be leaking from that check cap. Since the tractor is new I do not know if this is typical during a break-in period or I should be concerned there is something else going on. Luckily the LS dealer is great and he is only 4 miles from me, but before I took it in I thought I would ask all of you more experienced tractor drivers out there what you think or have experienced. And yes it is a 4WD, 2015 model.
Appreciate the support, I have learned a ton from you all. Thanks....
   / XJ2025H Right Front Axle Leak #2
Had the same thing happen on a LS2023. Either the blue cap is a little loose or axle may be over filled. Make sure tractor is level when checking dip stick & tighten blue cap about 3/4 turn past hand tight. This worked for me.
   / XJ2025H Right Front Axle Leak #3
I broke the blue cap on mine with some brush clearing. It has a rubber o ring in it you might want to check for leaking.
   / XJ2025H Right Front Axle Leak #5
Yes, it's a vent but it has some internals to prevent oil from sloshing out. I think it only cost less than 5 bucks from dealer
2021 FORD F-150XL CREW CAB TRUCK (A51406)
2021 FORD F-150XL...
2006 Cadillac STS Sedan (A50324)
2006 Cadillac STS...
2018 FREIGHTLINER COLUMBIA GLIDER TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
2016 Ford F-550 Crew Cab Mason Dump Truck (A51692)
2016 Ford F-550...
2012 Honda Accord Sedan (A50324)
2012 Honda Accord...
Club Car Electric Golf Cart (A51694)
Club Car Electric...
